3.0L Header Dyno #s ?
Old Mar 17, 2004 | 08:35 PM
  #81
2k5spd's Avatar
Originally Posted by BlackBIRDVQ
Pretty EZ job if U ask me, loosen the cross member, drop the OE or aftermarket Ypipe, remove the rear motor mount WITH the cross member attached. Then Remove the motor mount bracket that bolts up to the rear of the motor. For the front manifold I pull the radiator out- pretty ez job ( and I'ma be due for a coolant flush soon anyways ) just remove the hoses from the motor locations, unplug the fans from their connectors, remove the overflow hose that goes off the radiator neck nipple and then the 2 10mm bolts that hold down the brackets that hold the radiator down. I will write up my own procedure on how to install headers when mine arrive. I've done cats on a VQ30DE-K on the front so I know how the manifold comes off the front. I inspected CLOSELY- rear manifold and its fairly EZ job. I wanna say U can have it done in like 2-3 hours tops. **** pulling the motor out takes a whoppn hour not even, might as well do that if it takes ya dat long
FYI- I'm a mechanic, and I do things like these on daily basis- Maxima tranny takes 15 min to remove on my ride. Don't belive me, look where my sig line pic is taken
oh, is that all. well that's easy enough. all except for the fact that i don't know what the hell you just said. yeah, easy job if YOU'RE A MECHANIC.
Old Mar 17, 2004 | 08:56 PM
  #82
optimus310's Avatar
The hardest part is to remove the damn heat shield from the rear manifold. That this is like double layer heavy duty metal sheet. But maybe it would be easy for you 5th gen guys since your engine bay looks a bit bigger
Old Mar 17, 2004 | 09:15 PM
  #83
Larrio's Avatar
The Definitive AE Master
VQ30DE-K and VQ35DE have no EGR, so there should be no welding required. As for the downstream 02 sensors, I can use a simple resistor that DSM, WRX guys use to fool the ECU into thinking the cats work fine. In IL they only do the scanner part of the Emission test on all 96 and up cars. As long as all readiness tests have completed, and there are no DTCs stored the car will fly through the test.
could u please expand on the downstream o2 sensor thing. So what will I have to do to make this work assuming that physically the headers bolt up to the 3.0 engine
i thought 3.5 - 4 o2's and 3.0 - 4 o2's also? Is there a lack of o2 bungs or what?
Old Mar 17, 2004 | 11:56 PM
  #84
Y2KSESteve's Avatar
01s have four also I believe. If you need extra bungs, let me know and I'll overnight them.
Old Mar 18, 2004 | 12:24 AM
  #85
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What he's saying is that with ALL three cats removed or ALL four 02s in front of the only remaining cat, ie the main cat, the ECU will throw a CEL.
He's referencing a method of "tricking" the ECU into thinking the cat is still there by placing a resistor on the rear 02s.
All Cali spec cars have 4-02s. You must have the rear 02-sensors relocated behind the MAIN cat, ie b-pipe(like fed->cali conversion by DesertPearl) inorder to keep the ECU happy. However, people have installed the Stillen headers at least from my knowledge withOUT relocating the rear 02s or installing the 02 simulator/resistor/black box trickery and NOT get a CEL.
Old Mar 18, 2004 | 12:28 AM
  #86
Larrio's Avatar
thanks, i'll let you know steve.
I heard this from a maxima owner who installed the cattman headers:
on the manifolds, there are only two o2 bungs welded on. So cali spec cars will need to relocate their extra two o2 bungs further downstream after the main cat.
so i'm assuming these are where they are located:
here is the 2nd o2, so the other two have to be relocated (#3 zipped tied and #4 hanging by itself next to it):
also, the motor mount bolt hits the header piping in the front manifold (courtesy of Hnda Etr)
Old Mar 18, 2004 | 08:13 PM
  #87
Larrio's Avatar
so the options are:
1. relocated rear o2's after the cat (i.e. b pipe)
2. place a resistor mod to trick the ecu
right?
Old Mar 18, 2004 | 08:22 PM
  #88
IceY2K1's Avatar
No, just relocate 02s, just like DesertPearls website.
I'd do it ahead of time.
so the options are:
right?
Old Mar 21, 2004 | 10:56 PM
  #89
BlackBIRDVQ's Avatar
drag racing is for wussies
whats the word on the Cattmans ? I heard someone - SR20DEN runing them on the 3.5L and runing a 13.6MPH with awesome butt dyno results and barely any mods ??? I'm thinking of buying the headers this week as my Y-pipe is driving me nuts with yet the 5th leak....
user 11122324
42
Jul 18, 2022 03:35 PM
Socalstillen
Sep 26, 2015 12:01 PM
ac max 92
Sep 17, 2015 07:35 AM
tardrex
Sep 11, 2015 07:35 PM
