Improving sound dampening
Old Mar 12, 2004 | 07:22 AM
BrandonSE's Avatar
Alright guys, when i first bought my car it sounded alot quieter inside the car. I didnt realize it until yesterday when i was riding around in my friends lexus how loud the interior noise is. I know i dont have a lexus but is there anything to do that can help dampen the outside noise. I tried to use a 3m velcro piece the one that is made of cloth and basically insulate around the windows better. Is there a new rubber surrounding for the doors i can buy? Thanks in advance.
thanks
brandon
Old Mar 12, 2004 | 07:41 AM
SoonerFan's Avatar
Cletus
thanks
brandon
here is one thing you can check. i had the same problem and figured out the problem.
my door wasnt shutting all the way and it seemed a little loose when it was shut.
you know on the car where the door latches? i attatched a pic below to show what im talking about.
well that was loose so the door didnt have a good seal.
so i tightened it. you can actually adjust it a little. it slides to make it closer or further from the door. i ajusted it and now the door shuts all the way and no wind sound.
just something to try
Old Mar 12, 2004 | 07:45 AM
SoonerFan's Avatar
Cletus
and one more this that i saw on horsepower tv
close the door all the way.
fold a dollar bill and from the ouside run it along the seal. if it slides in you know where you have a bad seal.
then you can use cocking behind the rubber seal in that spot. it will push the seal out to create a better seal.
Old Mar 12, 2004 | 08:48 AM
maseo77's Avatar
he said COCKING..lol
Old Mar 12, 2004 | 12:55 PM
BrandonSE's Avatar
Thanks alot guys, i tried to look at the door latches and it seemed tight. When you adjusted it was it tight and you loosened it then moved it in? or was it loose and that was when you moved it in?
Soonerfan, i tried the dollar bill but it seemed good all around.
Maseo, ... lol
I was thinking about trying to stuff something in the rubber to make it seal better but i dont know what. I dont want to use cocking all around.
brandon
Old Mar 12, 2004 | 01:37 PM
Zero Deuce SE's Avatar
You know he meant caulking.
Old Mar 12, 2004 | 02:48 PM
NizanDrivn's Avatar
lol....
Old Mar 12, 2004 | 03:31 PM
SoonerFan's Avatar
Cletus
Maseo, ... lol
brandon
one was loose (the one that had the wind noise). when i realized i could adjust it, i adjusted them all just to be sure
SoonerFan's Avatar
Cletus
yeah, that too. i spelled it the way it sounds
Old Mar 12, 2004 | 03:46 PM
Benj-AMG's Avatar
There is a TSB on windnoise affecting the rear passenger window. Its common on all gen 5's apparently. Mine is doing the same thing. Took it Nissan yesterday and they didn't know anything about it. So I showed em the print out. They said they didn't have the foam piece used to fix it, that they had to order it. So that might be something to look into. Cocking.....
Old Mar 12, 2004 | 04:08 PM
BrandonSE's Avatar
I tried the thing on the tsb that shows whether or not you have the problem by placing a piece of tape around the outside window, that didnt solve the problem. I think it has to do with the door closing, and the rubber, thats why im hoping someone has a fix. I dont know, the sound went away from the drivers door that it used to make when it closed, the noise that a new car makes, like a sound solid. I dont know i didnt even care until i got into my friends Lexus and realized that the noise in my car has gotten louder. Like i said before i know im not driving a Lexus but i do remember getting in his car and thinking how it wasnt that much quieter just smoother.
thanks
brandon
Old Mar 12, 2004 | 04:46 PM
Benj-AMG's Avatar
Well I agree about that... My mom has an RX330 and its spooky quiet. But, the tape test might not mean much since they basically fix the rubber seal around both back windows. It's bound to help.
Old Mar 12, 2004 | 05:00 PM
Mass_Media's Avatar
Mass_Media™
I saw something on a show also....it said to get like a smoke machine or something like it and use the smoke (with the door closed and the window down) and move the smoke just under the crack of where the door is that way you can see where caulking needs to go. I haven't tryed it but when I saw it looked like it would work
Old Mar 12, 2004 | 06:04 PM
Maxnut's Avatar
be careful when adjusting the door. When I first bought my car, the rear door was adjusted too far in and that created a lip for rocks to chip. You want a smooth surface all around on the outside of the car or it will get chipped.
Old Mar 13, 2004 | 04:04 PM
BrandonSE's Avatar
This all sounds good, so basically i just need to buy some caulking and check to see where the seal isnt properly doing its job. I guess home depot my have caulk? Thanks alot
brandon
Old Mar 13, 2004 | 04:17 PM
Tony Fernandes's Avatar
thanks
brandon
Am I the only one that realizes his noise problem probably has little to do with the door & window seals? If your road noise has actually gotten louder over time, I'm guessing it has something to do with your tire wear. I don't know what tires you have, but many brands will get louder as the tread wears down. Buying quieter tires might have a surprisingly profound effect on road noise. Of course, there's other sound deadening material you can use, but it's extremely expensive and very heavy. I've heard mixed results as far as effectiveness. (no, I'm not talking about Dynamat, but a lead-based sound barrier coupled with traditional damping material, usually sandwiched together).
Tony
Old Mar 13, 2004 | 07:14 PM
JAKE02's Avatar
My Maxima wind noise has definately worsened esp from the passenger rear window......my dealer also played dumb when I asked about it? Where can I get a copy of this TSB?
Old Mar 13, 2004 | 08:42 PM
BrandonSE's Avatar
Yeah it is extemely bad, yesterday i went to the city and it got so bad that my passengers insisted their doors were open and i told them they werent they tried to close them while driving, you know open and close them, but the problem still persisted. I bought these wheels i got now, and the guy who i got them from put the wrong tire size on, i know that because Nissan told me, so i think what Tony said might have something to do with it also. Thanks alot hopefully more input for dampening will keep coming.
brandon
Old Mar 13, 2004 | 11:25 PM
bsetiawan's Avatar
Do you guys know that besides dampening materials, those Lexus also have noise cancelling devices ? Basically the noise is transformed into voltages and these devices generates the voltage in opposite magnitude to cancel those noises. IIRC this is the Correlation theorem taught in one of the EE classes. So no matter how much dampening materials you put in the Maxima, it's never gonna be as quiet as a Lexus.
Old Mar 14, 2004 | 12:28 AM
I didn't know Lexus used these, but I know some auto manufacturers use them. They're very effective.
Tony
Old Mar 14, 2004 | 01:22 AM
BrandonSE's Avatar
bsetiawan, if you look at what i originally wrote, i am not trying to get it to sound like a lexus because i know that i didnt pay 50g for my car, but i do remember when it did sound quieter in the car than it does now. But that noise canceling stuff is interesting. I didnt know about that.
brandon
Old Mar 14, 2004 | 09:20 AM
bsetiawan's Avatar
brandon
Sorry for getting out of topic in the above post Brandon. Even if there is no gap with the dolar bill test, I guess the rubber seals and other insulating materials on the Maxima degrade over time because of weathering. It may be possible to make your Maxima as quiet as before by replacing all those rubber seals.
Old Mar 14, 2004 | 11:39 AM
I sprayed silicone spray on the weatherstriping of my 92 SE and it still looked new when I traded it in nearly 10 years after I bought it. It keeps the rubber lubricated and pliable and also helps if you wash your car in the winter by preventing the rubber from sticking to the ice. I sprayed my 02 shortly after I bought it.
Old Mar 14, 2004 | 04:25 PM
BrandonSE's Avatar
bsetiawan, actually this is off topic myself but i am really interested, do you know of a site that might have more information on these devices?
Where can i get new rubber seals?
thanks alot guys
brandon
Old Mar 14, 2004 | 04:54 PM
thanks alot guys
brandon
http://www.trademotion.com/partlocat...=4&catalogid=2
Old Mar 15, 2004 | 02:23 PM
BrandonSE's Avatar
On that sight, i see the weather stripping should i just replace the entire rubber seals around the door, because i think that is only for the window portion?
thanks
brandon
Old Mar 15, 2004 | 02:34 PM
thanks
brandon
You basically have to navigate the site to find the parts you need for your car. There are some many different sections of weatherstripping on our cars.
Old Mar 15, 2004 | 04:55 PM
maximo-SE's Avatar
i have a 2k3 and my rear passenger window is just whack.... its making this low whistling noise..... i overheard someone actually used double sided 3m tape to fix the problem.... who was that again?
did anyone attemp to fix this problem besides bringin this to the customer service rep who pretends not to know anything?
Old Mar 15, 2004 | 06:05 PM
BrandonSE's Avatar
I used 3m velcro, there are 2 parts, the cloth one and then the hard part. I took about 2 inches of the cloth side and put it inside like the tsb says. I didnt see a change, so i guess that it didnt work or i have road noise coming from somewhere else.
brandon
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Sep 27, 2015 08:37 AM
