What causes clutch shudder?
Old Mar 17, 2004 | 02:44 AM
ssheltz's Avatar
Over the past few months my clutch has started to shudder when I engage 1st gear. If I let it out fast or extremely slow it's ok, but under normal driving there it shudders enough to make the exhaust bang a little.
Last time I was at the dealer for something else I asked them to look at the clutch and they said I had plenty left (I would hope so with only 49K on the car).
What causes this and more importantly, is there an easy cure?
Old Mar 17, 2004 | 06:55 AM
redstradic's Avatar
only thing i could find since search is wacky right now.
http://forums.maxima.org/showthread....hlight=shudder
Old Mar 17, 2004 | 08:39 AM
Kiosk's Avatar
I just went thru the same symptons that you described. for my case it was oil leaking from the rear main seal into the clutch, so had to get that seal replaced and new clutch kit installed.
IT could be the same or that your clutch has developed hot spots that cause the shudder, also the flywheel might need to be resurfaced.
At any rate expect to have to replace your clutch to get rid of the shudder.....
Old Mar 17, 2004 | 08:47 AM
Kiosk's Avatar
Old Mar 17, 2004 | 09:07 AM
ssheltz's Avatar
thanks Mark.
I think the rattle I am hearing is not the exhaust but the rear deck vibrating. Didn't you do something to fix that rattle?
Old Mar 17, 2004 | 12:42 PM
redstradic's Avatar
well the rattle that was coming from the rear deck was due to the the sub and me listening to the music to loud. it was not from everyday driving. i cut up a twin mattress foam padding to the shape of the rear deck and stuffed it back there.
Old Mar 17, 2004 | 12:55 PM
CT MAXOUT's Avatar
Most likely the clutch needs to be replaced. Its normally caused by uneven wear on the flywheel or "hotspots" as was stated earlier. Just be sure that the shop that replaces it re-surfaces the flywheel or replaces it new or it will just continue to happen.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
