advice with dash kit
Old Mar 17, 2004 | 06:13 PM
greenguy's Avatar
any body have any advice when installing a dash kit? I have one sitting in my basement. just waiting until I have the time to install it. Can you give me any warnings before starting?
Old Mar 18, 2004 | 12:46 PM
jattmax's Avatar
make sure you clean the surface real good with 3m wax remover or a similar product.... it'll get off all that grime and make it stick real good... other than that make sure U PUT IT ON STRAIGHT the first time, otherwise it'll be a biatch to adjust later...
Old Mar 18, 2004 | 02:49 PM
BrandonSE's Avatar
Yeah like Jattman said, make sure that the polish, armorall everything is off the dash that you are applying the kit. If it doesnt stick grap a blow dryer and put it on the sticky side of the kit, once its heated up, not too hot, you should be able to apply it again. Enjoy
brandon
Old Mar 18, 2004 | 02:54 PM
Progress's Avatar
It's business time.
And don't make the mistake I did and try to install it when it was below freezing out. I had to keep my car running with the heat on trying to warm it up. I ended up using super glue in some areas, it turned out ok.
Apr 16, 2020 05:15 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Pied
Sep 26, 2015 03:29 PM
