My A/C Vents Stink..!
Old Mar 18, 2004 | 10:22 PM
A33 VQ30DEK's Avatar
hey guys well my vents stink and only when the A/C is on.. i believe its mildew build up but i'm not quite sure. Have any of you guys had this problem? if so what was it and how did you deal with it?
-Brian
Old Mar 18, 2004 | 10:33 PM
LithiuMax
It's gotta be the AE kit...
Old Mar 18, 2004 | 10:41 PM
come on ilya gimme a real answer haha
Old Mar 18, 2004 | 11:40 PM
Zero Deuce SE's Avatar
-Brian
Sounds like mold or mildew inside your evaporator housing. You will need to clean it out and make sure that the drain is working.
Old Mar 18, 2004 | 11:42 PM
bsetiawan's Avatar
Brian, don't set your A/C to recirculation all the time. It's better to set it to open ventilation.
Old Mar 19, 2004 | 12:09 AM
carabuser's Avatar
my vents stink only when I set them to open ventilation (no A/C on tho). Still don't know what the problem is
Old Mar 19, 2004 | 05:12 AM
Ammi's Avatar
350 Detroit Muscle
It's mold building up. Turn on your AC, take a can of lysol, go outside, look near the winshield wipers for some holes, spray lysol in there. It will get rid of the smell.
Old Mar 19, 2004 | 05:41 AM
paralyse's Avatar
I Miss My Maxima
Yeah -- mold and other nasty stuff (dead rats come to mind) can get inside your evap core and cause a nastier smell. Make sure as stated above you run it in fresh air mode occasionally!
Lysol works good; also, BG (?) makes a product called Frigi-Fresh that is designed specifically for removing mildew/mold from AC units. Turn the heater on full blast, make sure it's set to outside air, and spray the can down the vents near your wipers, as stated above.
Sometimes I've had to do this 3-4 times to get the smell completely gone.
While you're at it, check to make sure your evap drain tube isn't clogged up. If condensation backs up inside the housing it will first cause this bad smell and eventually it will flood your carpet out!
Old Mar 19, 2004 | 10:01 AM
Mack Daddy's Avatar
I had this problem in an old jeep of mine. It smelled like a$$ everytime I turned on the ac. I tried everything including changing my carpets but it still stank. Anyway I had to have the evaporator changed which is behind the dash. A real PITA. Way expensive but the smell left. Hope that isn't your issue. I hope it is just mold or something like that.
Old Mar 19, 2004 | 10:28 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
First, swap your HEPA filter if you have one.
Second, from now on, anytime you use the A/C system, turn-off the compressor(push button) and leave the fan running until warm/outside air begins to flow, THEN turn off the car. Otherwise, the cold air condenses and makes moisture, which turns into mold and next time you turn on the A/C it stinks.
Trust me, it works.
Old Mar 19, 2004 | 11:47 AM
takkar's Avatar
Another thing is that during the winter...people don't use their A/C's at all...there might be some water accumalated which might stink after some time....so turn your A/C on after a week or so during the winter ( this will avoid any seals cracking too)
Miket2006
Mar 1, 2021 03:55 AM
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
