KINETIX intake manifold for the 350Z
Old May 10, 2004 | 02:13 PM
  #121
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Yes, and the lower intake manifold *MIGHT NOT* solve that or be *ANY* different.
Something else I'm hoping maximaman777 will be able to eliminate besides the bolting up issue, since I don't believe Ethan ever finally bolted it down.
Old May 10, 2004 | 04:37 PM
  #122
Quicksilver's Avatar
OT n00bs FTMFCSL
Originally Posted by SR20DEN
And history repeats itself.
I suppose none of you remember that Ethan tried this already. The 350Z manifold will NOT fit.
You'll forgive me if I say we would prefer to actually try to make it work rather than take someone's word on it that it won't. There's not nearly enough information or trial and error in this particular matter for my tastes, which is precisely the reason Adam and I will be trying this out. If we find a way to make it work, or find a way to get the intake easily adapted to suite our needs, then I assure you, we will have accomplished something good. Even if nothing works out, it's still good in that it will be absolute proof that this particular idea will not hold water...
Matt, any new developments that you'd be willing to share with the entire .orgy, or is it a possible money loss matter to discuss anything at this time (custom intake)?
Old May 10, 2004 | 04:41 PM
  #123
OT n00bs FTMFCSL
Very true. We have no idea if the bolt holes will even line up on this thing...
Old May 10, 2004 | 05:07 PM
  #124
MaxSE2k's Avatar
Originally Posted by 03BlkSETE
Spare IM, meaning upper and lower parts, or just the upper plenum?
Now this would be a useful piece of information before we all go spending $$$.
Guys?
Based on your diagram, it appears as though parts #11 & 4 are required:Diagram
Please confirm.
Old May 10, 2004 | 06:26 PM
  #125
MaximaMan77's Avatar
Guys?
Please confirm.
Originally Posted by maximaman777
This isn't an attempt to make it work on the Max. Lloyd is the one who bought it for his G35c. We're just going to test fit it and check for clearance issues and maybe see how it runs before we install it on his car.
No negetive waves Moriarty.
We plan on measuring and using if needed the LIM from the G...
Old May 10, 2004 | 06:43 PM
  #126
MAXINXS's Avatar
Couldn't you have Kinetix do a rubbing of the bolt holes from the underside of the manifold and fax that to you!? Then you could see if it will line up to our stock holes before getting to deep in the modification.
Old May 11, 2004 | 05:10 AM
  #127
MaxSE2k's Avatar
I quoted a question that was directed to SR20 & Blu, therefore my question was also directed towards SR20 & Blu. Thanks anyways.
Old Jul 12, 2004 | 01:00 PM
  #128
MAXINXS's Avatar
Any updates on this?
Old Nov 4, 2008 | 08:13 AM
  #129
sureal00's Avatar
anybody ever install this manifold on there maxima ?
http://www.kinetixracing.com/newalti...fold02-06.aspx
I wonder if you install the nwt intake spacers as well if you would get around 22 hp together and 26 lbs ft torque
what do u all think ?
Old Nov 4, 2008 | 08:40 AM
  #130
HotshotVQ35's Avatar
you are kidding right?
Old Nov 4, 2008 | 09:06 AM
  #131
sureal00's Avatar
Am i kidding on the total hp and torque or am i kidding about getting that ?
Old Nov 4, 2008 | 10:03 AM
  #132
mist max2000's Avatar
alot of info on that.. cliffnotes: it ahs yeilded lower hp/tq ratings when bolted on.. unless someone is spraying or FI,..its up in the air.. search on it,.. if u have a G to spend on it.. then get it and report back your findings lol...search SSIM
Old Nov 4, 2008 | 10:18 AM
  #133
this is an interesting read..
http://www.nissanclub.com/forums/eng...-vs-stock.html
Originally Posted by mist max2000
.search SSIM
Old Nov 4, 2008 | 10:28 AM
  #134
Fastmax05's Avatar
"Ok,Whats next?!?!"
duesexmax has had this on his max for a LONG time... he's a 6th gen...
and you can find them for liek 760 shipped now
Old Nov 4, 2008 | 10:54 AM
  #135
sureal00's Avatar
thanks that was a good read.the kinetix manifold is nice to look at haha
Old Nov 4, 2008 | 11:01 AM
  #136
solid read.. might pick up a block off plate and see how it feels lol
Old Nov 4, 2008 | 02:48 PM
  #137
its only 40 bux! cant hurt!
Old Nov 4, 2008 | 08:24 PM
  #138
Scottwax's Avatar
That's Mr. Detail to you
Nearly as much gain as headers and a much easier install.
Old Nov 4, 2008 | 08:30 PM
  #139
Scottwax's Avatar
That is interesting. Other than some loss between 3000-3800 rpm, you gain power the rest of the way. Could be the loss at lower rpms (and really, only noticable in first gear at the strip) could be enough to make our cars hook up better anyway. Once you get past 20-25 mph, you'd pull harder the rest of the way.
Anyone do this and the intake spacers? I wonder if the spacers help you get back some of the 3000-3800 rpm loss?
Old Nov 4, 2008 | 09:30 PM
  #140
adrenaline_rush_fanatic's Avatar
I got the block plate(VIAS delete) and GAB w/K&N....
It's felt WAY better than stock...
With the stock airbox before, I bogged and rocked when punching it (the VIAS opening under compression made a delay) because of poor throttle response.
did the GAB + K&N and throw the NWP block plate on and voila...
much better gains I feel.
Old Nov 5, 2008 | 06:20 AM
  #141
im going to pick one up in a week or 2.. and ill report back my findings only other mod besides suspension would be berk intake w/ apexi filter...
Old Nov 5, 2008 | 06:31 AM
  #142
DrunkieTheBear's Avatar
Turbo'd Saab
do you have a 3.5?
as far as the 3.5 plenum kinetix from the 350z it will fit both the 3.5s and the 3.0s. you just need a 350z LIM, but with the 3.0 guys you have to do a little port matching, I just ordered a LIM for $0 and I'm going to take pics of how it matches up with the 3.0 heads.
Old Nov 5, 2008 | 08:33 AM
  #143
yup.. see sig
Old Nov 5, 2008 | 10:25 AM
  #144
Turbo'd Saab
yup.. see sig
HAHA missed that...I went by user name LOL
Old Nov 6, 2008 | 01:17 AM
  #145
I hope to hear good news soon.
This is really very interesting guys [and exciting]!
Woot!
Old Nov 6, 2008 | 06:39 PM
  #146
Scottwax's Avatar
Anyone with an automatic do the block off plate? The top end charge looks good but at freeway speeds, I'd be right on the dead zone so it seems part throttle response would be a bit soft. Plus when you get on it at 60 and it only drops to 3rd, you have a bit of time before it gets to 3800 rpm and pulling harder. I wouldn't mind the extra power from 3800 rpm up but I don't want to sacrifice drivability.
Old Nov 6, 2008 | 07:22 PM
  #147
NiZMo1o1's Avatar
Why dont you look at Jimes setup ? Im switching over to the MREV2 in Dec , your going to modified the Neck of the manifold.
Old Nov 6, 2008 | 07:23 PM
  #148
NiZMo1o1's Avatar
theres a few 6th gen guys running this already
Old Nov 7, 2008 | 11:26 AM
  #149
NmexMAX's Avatar
dot dot dot ...
@ same gain as headers.
Old Nov 7, 2008 | 04:55 PM
  #150
Scottwax's Avatar
If as said, the intake + spacers is a 22 hp/26 lb-ft gain, then yes, that is about the same as headers and for a lot less labor.
Old Nov 7, 2008 | 06:37 PM
  #151
do you have headers?
Old Nov 7, 2008 | 08:16 PM
  #152
Scottwax's Avatar
Nope. Haven't decided exactly what I want to do to the car, but the block off plate sounds promising, assuming the lower power between 2800-3800 rpm doesn't mess up drivability and throttle tip-in too bad with an automatic. Probably that, UDP and the intake spacers will be my first mods beyond the easy stuff like GAB.
Yearly emission testing here and they really looked over the area where the O2 sensors were when my car was last inspected. I'd have to make sure O2 sims were well hidden if I want to go with headers.
Old Nov 7, 2008 | 08:33 PM
  #153
DeusExMaxima's Avatar
Here it is on mine:
Old Nov 7, 2008 | 10:18 PM
  #154
Scottwax's Avatar
Originally Posted by DeusExMaxima
Here it is on mine:
Looks great. What are your impressions of the performance improvement?
Old Nov 8, 2008 | 10:53 AM
  #155
NmexMAX's Avatar
dot dot dot ...
Peak values = poo poo.
I gained nearly 20 whp w/ just a POP charger.
Area under the curve is what really means more.
Old Nov 8, 2008 | 01:09 PM
  #156
Scottwax's Avatar
True, but the dyno sheet shows gains most of the way through the rpm range with the Kinetix intake and even at low end it was at least the same as stock.
Old Nov 8, 2008 | 06:05 PM
  #157
Norkoastal's Avatar
I just took out the butterfly and slapped the NWP plate on.. Haven't driven much, but the low end loss isn't big enough for me to worry about.. Getting on the freeway and quickly merging into traffic was much more quick and linear than before, so that was an immediate difference from before.. I'll throw some more feedback up as I test out the car on all surfaces..
Old Nov 8, 2008 | 08:20 PM
  #158
Scottwax's Avatar
That's what I was hoping to hear.
BTW, how do you like the Transgo Shift Kit?
Old Nov 9, 2008 | 12:07 PM
  #159
Norkoastal's Avatar
1-2 is tighter when steady accelerating with a slight nudge. Slow stop and go 1-2 is jerky.. The rest of the gears are tighter with minimal difference in comfort. Overall a nice mod.. I still need to get a tranny cooler and will likely be swapping the solenoids if this little spike issue keeps showing its ugly little head.
Old Nov 9, 2008 | 04:41 PM
  #160
Scottwax's Avatar
Are you talking about the 2-3 spike when cold?
