question bout resetting ECU on 2k2..
Old Mar 19, 2004 | 04:52 PM
mad_maxx03's Avatar
I'm fixing to go out and install my new intake, and am going to reset the ECU.
http://www.technosquareinc.com/350reset.htm
Would you guys recommend doing every one of the resets?
Thanks, be back in a lil bit with my new INJEN
Old Mar 19, 2004 | 05:18 PM
Manaz101's Avatar
Yes, i would.
Here's a shorter version
Old Mar 19, 2004 | 05:26 PM
mad_maxx03's Avatar
thanks for the reply bro, im defiently resetting the ECU, but i was wondering about the following, should I do these?
Accelerator Pedal Release Position Learning
Operation Procedure
1. Make sure that the accelerator pedal is fully released.
2. Turn ignition switch “ON” and wait at least 2 seconds.
3. Turn ignition switch “OFF” wait at least 10 seconds.
4. Turn ignition switch “ON” and wait at least 2 seconds.
5. Turn ignition switch “OFF” wait at least 10 seconds.
Throttle Valve Closed Position Learning
Operation Procedures
1. Make sure that accelerator pedal is fully released.
2. Turn ignition switch is “ON”.
3. Turn ignition switch is “OFF” wait at least 10 seconds.
Make sure that the throttle valve moves during above 10 seconds by confirming the operating sound.
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Old Mar 19, 2004 | 05:57 PM
Manaz101's Avatar
To be honest with you, i've never had to personally reset my ECU, the times it's been done it's been by my friend. I pulled the picture from his website. I'd just do it his way......i've got a 2k2 and it worked perfectly.
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
Colossus
Sep 9, 2015 05:46 AM
