HELPPPP I BROKE SOMETHING! Dont know what it is
Old Mar 21, 2004 | 02:37 PM
mad_maxx03's Avatar
Was messing with FSTB, cleaning engine and such and made a booboo.. Broke this while putting back on FSTB, being careless Can someone please tell me what it is? I started car, tried windshield wiper and nozzle, it all works...
Old Mar 21, 2004 | 02:39 PM
2k3TitaniumSe's Avatar
Looks like something to do wqith the power steering.
Old Mar 21, 2004 | 02:48 PM
mad_maxx03's Avatar
OH no, i hope not, fixin to drive it up and back just a little and check,,, oh god...
Old Mar 21, 2004 | 02:51 PM
KLOOGY's Avatar
L33t BMW Drivah
I almost did the same thing yesterday, when I put my FSTB back on after spring swap...
Old Mar 21, 2004 | 02:52 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
somethin to do with A/C??
Old Mar 21, 2004 | 02:55 PM
mad_maxx03's Avatar
I have no clue what it is, but when I start the car it has a bad rumble to it, and a rough idle also
03BlkSETE's Avatar
I'm going to go with A/C also.
Old Mar 21, 2004 | 03:34 PM
mad_maxx03's Avatar
Well, I don't know what it is, might go to the dealership tomorrow and ask em, but for now I'm going to try to drive it. Hopefully it won't catch fire or anything
Old Mar 21, 2004 | 03:44 PM
CT MAXOUT's Avatar
Ditto. Its got to be some sort of A/C sensor. Its a pressurized, insulated line its in. It won't pose a danger.
Old Mar 21, 2004 | 03:53 PM
mad_maxx03's Avatar
I was thinking, could be wrong, but... Could it be the themometer thing? It's been at 53 ever since I did it, and its really 71. Dunno though..
Old Mar 21, 2004 | 04:06 PM
Zero Deuce SE's Avatar
That is your power steering pressure sensor. It sends input to the ECM when the steering system is under load so it can adjust engine speed to prevent stalling the engine.
Old Mar 21, 2004 | 04:14 PM
The outside temp sensor is in the front end of the car. You will just have to buy another power steering pressure sensor, install it and plug it back into the harness. Time to call Dave B.
http://www.trademotion.com/partlocat...16&catalogid=2
Old Mar 21, 2004 | 04:18 PM
01SE02SER's Avatar
Faster than a speeding bullet...
I'm looking at a drawing of it right now, and it matches your pics.
From the Electronic Service Manual...
"Power steering pressure (PSP) sensor is installed to the power steering high-pressure tube and detects a power steering load. This sensor is a potentiometer which transforms the power steering load into output voltage, and emits the voltage signal to the ECM. The ECM controls the ETC actuator and adjusts the throttle valve opening angle to increase the engine speed and adjusts the idle speed for the increased load."
Good luck.
Peace.
Old Mar 21, 2004 | 04:22 PM
Good luck.
Peace.
"You talkin' to me?"
Old Mar 21, 2004 | 06:35 PM
mad_maxx03's Avatar
Damn, so can I drive it for the time being?
What do I need to order from DaveB exactly?
Thanks guys
Old Mar 21, 2004 | 07:01 PM
irish44j's Avatar
retired moderator
Someone else posted tht they had done this a while back too...it was the P/S sensor, and he said his steering was VERY heavy (as if he did not have P/S) until he got it fixed......car should still be driveable, but be really careful bc you may have to put some muscle into steering if your P/S is messed up.
Old Mar 21, 2004 | 07:06 PM
2002 Maxima SE's Avatar
Close, our Maximas have speed sensitive steering. More power when at slow speeds (manuevering a parking lot) less at highway speed. The computer probably doesn't know what to do.
Old Mar 22, 2004 | 03:02 AM
Of course it knows what to do. At highway speeds, you would not ever put a load on your power steering because you can't do a high speed u-turn. If you turn your wheels to extreme right or left, the p/s system will be loaded and produce high pressure. If idle speed was not adjusted by the ECM, the rpm's would drop to the point that the engine could easily stall. Just as when you turn on your A/C compressor or high amperage drawing systems on the car.
Old Mar 22, 2004 | 03:07 AM
Thanks guys
Did you look at the link I provided? It's the pressure switch in that diagram. Just tell him that you need a new power steering pressure switch (sensor) for your car. It may be safe to drive as long as there is no fluid coming out of the exposed end of the switch when you turn the steering wheel. Keep an eye on it and your fluid level in the reservoir.
Old Mar 22, 2004 | 08:47 AM
panda_1's Avatar
its actually running to 2 rails on the front and the back of the motor, the front one runs under the boost sensor.
Old Mar 22, 2004 | 09:28 AM
Does it reallly matter where it runs to? His pressure switch is broken and he needs a new one. The switch goes in the pressure line shown in his pictures.
MaxDD
Sep 24, 2015 06:40 AM
220k+ A32
Sep 23, 2015 03:38 PM
dcam0326
Sep 18, 2015 04:52 PM
seesole
Sep 14, 2015 12:38 PM
