Bolt size to counter-screw rotors off on a 2000 maxima?
Old Mar 25, 2004 | 05:23 AM
SkoorbMax's Avatar
8mm isn't it, so I think it's either a 9mm or a 10 mm metric. I'm guessing 1.25 pitch? My Haynes says to use one of the right thread size <- thanks for nothing, haynes!
Does anybody know which bolt size to use?
Old Mar 25, 2004 | 05:46 AM
Spin20's Avatar
Did you try to use a rubber mallet? I sprayed some WD-40 on mine around the studs and tapped the rotor and it came off.
Old Mar 25, 2004 | 05:53 AM
SkoorbMax's Avatar
I tried briefly last night, but it was too late to give it a good go. I can probably do it with a mallet, but I wanted to have some screws just in case, because I hate having to drive 10-15 min to the tool store every time I need extra stuff
Old Mar 25, 2004 | 06:16 AM
tkostiuk4's Avatar
use a rubber mallet, if you don't want to use one then it doesn't really matter if the screw is the right size for your not keeping the rotors are you?
Old Mar 25, 2004 | 06:39 AM
SkoorbMax's Avatar
Huh? I'm going to try the rubber mallet, but if it doesn't work I want the real bolts and if I know what they are I can pick them up when I'm at home depot (which I have to go to anyway), thus saving me a big hassel later
Old Mar 25, 2004 | 01:59 PM
irish44j's Avatar
retired moderator
good question, I was wondering the same thing....thanks for nothing Haynes!
Interesting, the 2k4 rotors I am putting on do not have the screw holes on them at all......
I have taken the rotors off before and you can do it with some brute force and some tapping of a mallet...
Old Mar 25, 2004 | 02:31 PM
foodmanry's Avatar
Da Roller Coaster!
Metric or standard will work. I believe the metric size is a 12MM head. In standard that equates to about 5/9. YOu have some leeway with that.
Old Mar 25, 2004 | 02:59 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I turned my rotors in my Maxima a few times (pads are the culprit of warping rotors btw I did my own R&D here) I just wack the rotors with a hammer right in the hub part of it, that frees up the rust and rotor usually just pops right off. Gets some Hawk HPS pads for it !!
Old Mar 25, 2004 | 05:01 PM
SkoorbMax's Avatar
Thanks guys - I ended up actually getting the rotor off quite easily with my mallet. I'd also heard about tapping the rust away by nailing the center of the hub with a hammer, but it turned out to be unecessary. I'm really trying to keep expenses to a minimum, so I'm thinking about resurfacing the rotors at $15/pop vs. $50/pop shipped for brembo blanks or $70 shipped/each for nissan OEM from dave B. What do you think? Here is a picture of the front left rotor to see its condition (some of the funny markings are just rust - it looks pretty good close up, except for the darker "ridge" in the middle, which you can't really feel).
"pads are the culprit of warping rotors btw I did my own R&D here" What do you recommend? If I end up turning my rotors I am going to go with local pads, so autozone ($34/pair carbon metallic), or OEM $70/pair.
BTW I drive quite gently and am not hard on my brakes.
Old Mar 26, 2004 | 03:27 AM
SkoorbMax's Avatar
Bumpers!
Old Mar 26, 2004 | 05:48 AM
cobymoby's Avatar
I've had good results from the Performance Friction carbon metalic. i think that they are available from most local auto parts stores. I went through 3 sets of front rotors (all OEM) with the OEM pads. This was all in one year. They don't take performance driving very well and would start to smoke on me after driving hard for a while.
After switching over to the Perf Fric pads and a new set of rotors my problems were gone. On my second set of perf fric pads on the same set of rotors. i didn't have to turn them.
Old Mar 26, 2004 | 05:49 AM
Maxpat82's Avatar
They look in good shape to me!!!
If there's no groove on them why resurface them?
Are they wrapped!!
Old Mar 26, 2004 | 06:42 AM
SkoorbMax's Avatar
Good to hear about the performance friction pads - I think they're the ones I'm eying.
"Are they wrapped!!" I think they are! I've got some healthy throbbing/vibrating when braking from medium to highspeed at medium to high braking. I plan on turning/resurfacing them, and then throwing on the new pads.
Old Mar 26, 2004 | 07:44 PM
irish44j's Avatar
retired moderator
Back to the original subject -
I just switched rotors to day (see BlehmCo thread) and used the screw to counter-screw the rotors off (which is VERY easy - takes about 1 full turn and its off).
Anyhow, the screw is a 10mm, 1.25 pitch, fine thread.
Old Mar 26, 2004 | 07:52 PM
SkoorbMax's Avatar
Thanks for the answer
ah2002
Mar 9, 2016 01:42 PM
03VQMAX
Sep 25, 2015 04:19 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
RealityCheck
Aug 5, 2015 06:18 AM
