6 spd
Old Mar 27, 2004 | 07:17 PM
rbourne's Avatar
6 spd
Getting a strange creeking sound on my '02 when I press the clutch. Anyone have the same. You can hear it from the outside.
Old Mar 28, 2004 | 04:08 AM
Bluesbrekr's Avatar
Doctorate in Detailing
The creaking sound I had was the clutch spring. I don't know if it could be heard outside the car. A bit of grease where the spring is attached took care of it.
Old Mar 28, 2004 | 11:18 AM
maxS
a while ago i got a creeking sound too when i pressed the clutch... I went under the dash, started checking the thing and all... What i figured is that the seat does the creeking!
Old Mar 28, 2004 | 06:33 PM
GuZo's Avatar
Mine creaks too, good thing you reminded me since my car is going in there this week.
Old Mar 28, 2004 | 08:54 PM
studman's Avatar
It's the clutch return spring.
Be sure your parking brake is set and that the engine is off. Look under the dash and upwards. Get some silicone grease and put a dab on your finger (a very SMALL dab). Then push the clutch pedal down and rub that on the spring.
Old Mar 29, 2004 | 04:38 AM
rbourne's Avatar
6 spd
I greased the spring with no success. The creek is coming from the tranny when the clutch is depressed. Let me know your outcome. Can anyone comment on the mechanics of the clutch?
Old Mar 29, 2004 | 05:00 AM
2k2MerlotSE's Avatar
JUVIN's ride
I hear something when I let my clutch go after taking it out of first gear.
It only happens when it is cold, not sure what it is. It sounds like a spring pop, this started after I had the TSB done on the clutch. I am still looking into the noise, if I find anything I will post it.
Old Mar 29, 2004 | 05:14 AM
rbourne's Avatar
This sounds like the same problem I had before the TSB on the clutch. After having it fixed the "howling" went away but it's back again.
Old Mar 29, 2004 | 04:56 PM
ABS's Avatar
ABS
Yes, I have the same "creeking" sound in my '02 Max. I believe it is from the "fingers" on the clutch plate being depressed and making a little noise. The fingers on the plate are spring loaded and under very high pressure, but there is metal to metal contact. The noise is annoying, but it does not indicate a problem of any type. This is a very different sound from the clutch "howl" that yielded a TSB.
By the way, I once had a Honda that did the same thing once I reached about 80k.
Old Mar 30, 2004 | 12:30 PM
rbourne's Avatar
How many miles does you Max have? Mine has 44k. Did you bring your '02 in for service? If so what was the outcome?
Thanks,
Bob
Old Mar 31, 2004 | 09:27 PM
ABS's Avatar
ABS
Thanks,
Bob
I have about 49K. I did not bring it in for service. As far as I can tell it is normal for clutches to make this sound as they age.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
thatcollegestudent
18
Oct 5, 2015 02:29 PM
ef9
Oct 4, 2015 08:43 AM
220k+ A32
Sep 11, 2015 02:18 AM
