2k2+ Bulb replacement>>>HELP
Old Mar 28, 2004 | 09:09 AM
2k2MerlotSE's Avatar
JUVIN's ride
Hey guys,
I need to know if the clip goes around the bulb or the connector?
Reason being I tried putting back the bulb and it has been over an hr and I can not put it in. I though it went over the plastice connector. Then I put the bulb in without the connector and the clip went over it no probelm.
The only thing is the buld seems to be loose, I can move it around a little.
Is that normal?
Oh by the way I think I broke my bulb, the little rod on the side of the buld cracked . Did it brake?
Old Mar 28, 2004 | 02:33 PM
Playero's Avatar
Sanduguero
Originally Posted by 2k2MerlotSE
Hey guys,
Is that normal?
it goes around the plastic.... and i think you did break it...
Old Mar 29, 2004 | 04:55 AM
JUVIN's ride
No. it is the little rust looking rod that hangs off the side of the buld and goes down into the housing.
I figured out what I did wrong.
I should have put the bulb in first strap it down and then twist the cap on.
Everything is back together and the light still works. I am not sure for how long.
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
knight_yyz
Nov 1, 2015 01:34 PM
Noela
Sep 26, 2015 08:22 AM
