passenger door heavy/tight
Old Mar 28, 2004 | 04:48 PM
djfrestyl's Avatar
Suspension Yoda
realized recently that my passenger side front door is really tight and heavy. havent taken the door panel off yet but im hoping that a little bit of lube will help it out. anything u guys can give me tips on? what sort of things should i look for...and if all i need is lube...which should i use?
Old Mar 28, 2004 | 05:14 PM
PearlWhtMaX2000's Avatar
yeah i had the same thing. just put a lot of lube, and swing the door back and fourth for a while to let the lube spread.
Old Mar 28, 2004 | 05:18 PM
Zero Deuce SE's Avatar
Spray some white lithium grease on your door hinges and door stop rods.
Old Mar 28, 2004 | 06:29 PM
bert's Avatar
You don't have to take the door apart, that black plastic guide is not what is sticking. It's the pins, what holds the door to the frame.
Find some spray on lithium grease and go to town. While you are at it, do all the doors. Do it once a month (so you can forget every now and again) and you will never have problems again.
Old Mar 28, 2004 | 06:35 PM
TravisC's Avatar
I've got the samething with mine. I'm never in the passenger side so I didn't know until I started working on putting my TV and HU in. I guess I'll have to lube everything up.
Old Mar 29, 2004 | 11:29 AM
djfrestyl's Avatar
Suspension Yoda
sweet..thanks ill let u know how it goes
Old Mar 29, 2004 | 04:38 PM
grey2002_ny's Avatar
That's weird I had the same thing happen to me. Just the passenger door, none of the others are a problem and have never been. Wonder why it would happen to a bunch of different people. Anyway I'll just have to spray the s*it out of it and loosen it up a bit.
Old Mar 29, 2004 | 05:23 PM
redstradic's Avatar
haha, got the same problem here. i just have been too lazy to get the grease. next thing i gotta do though!
Old Mar 29, 2004 | 06:31 PM
wavedog's Avatar
Just the front passenger door here also.. Starting to see a pattern here... I'll have to get in the lube habit like I do with the antenna on the pathfinder and 89 max.lol
Old Mar 29, 2004 | 06:34 PM
Ammi's Avatar
350 Detroit Muscle
If you got some WD-40 sitting around, it should do the trick.
REDinLV
Aug 15, 2024 12:30 AM
doctorpullit
Mar 29, 2016 11:08 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
Noela
Sep 26, 2015 08:22 AM
