ATF drain and Refill
Old Mar 29, 2004 | 04:04 AM
wcasskicker's Avatar
Hi all members, my 2k max is due for ATF drain and refill. I've read through the
how-to flush ATF, but I don't seem to understand it without pics. Does anyone
have any links to ATF drain and refill procedure with pics? What tools are
required to refill the new ATF fluid (eg: tubing or siphon??). Appreciate all your
help...thanx
Old Mar 29, 2004 | 04:53 AM
Jime's Avatar
The first link is the how-to and the second has all kinds of pics of a tranny cooler install which shows both lines.
You don't need any tools other than to take out the sump plug and remove the line from the transmission and a clean 1 gal jug.
Refilling is done through the dipstick hole so you need an appropriate funnel or tube to fit your ATF container.
https://maxima.org/forums/4th-generation-maxima-1995-1999/33563-car-died-4.html
https://maxima.org/forums/showthread.php?t=33563&page=4
Old Mar 29, 2004 | 04:54 AM
cobymoby's Avatar
help...thanx
It's very easy, don't be affraid to get under there. It's as easy as an oil change.
Just undo the drain bolt, and refill with fluid through the ATF dipstick hole with a funnel. You might want to pickup a drain bolt gasket from the dealer. They're about a $1. I've had better results with using Mobil 1 synthetic ATF over the OEM Nissan Matic-D fluid. They cost the same.
Old Mar 29, 2004 | 06:54 PM
Mom's2kGLE's Avatar
The only problem with drain and fill is not all the old fluid comes out and then you re mixing nice clean fluid with the left over. Take it to the dealer they have a machine that gets all the old out and replaces it with new. I'm all for the DIY but there are certain things to let the pros do.
Old Mar 29, 2004 | 06:56 PM
Thanx....appreciate u guys help....
Old Mar 29, 2004 | 07:28 PM
A mechanic recommanded me to do the drain and refill first. He said Trans is very sensitive machine. Let trans accustom to the new fluid it a couple month, then do another drain and refill. after 6 month, Trans are used to the clean fresh fluid, then flush all the old one out.
What does everyone think?
Old Mar 29, 2004 | 10:49 PM
Jime's Avatar
With a drain and fill that is correct.
However if you read the how-to I posted you will see that this is not a drain and fill. It is a flush, you are not mixing nice clean fluid with any left over and when pumping out the old you can actually see the change when the new fluid starts to come out.
This can be done very easily and efficiently without going to a pro and wasting your money.
PS The standard dealer method is just a drain and fill and is the recommended way in the Factory Service Manual. Just going to a dealer does not ensure you are getting the best service.
Old Mar 29, 2004 | 11:14 PM
cobymoby's Avatar
The dealer will sometimes try to sell you some other services like this hi temp detergent fluid change for around $100. For something as simple as a tranny drain and refill I don't see why you shouldn't do it yourself and save $50.
Old Mar 30, 2004 | 02:08 AM
THanx Jime, your write-up is very helpful. I'll do it today and see how it goes.
Old Mar 30, 2004 | 03:07 AM
RAZORFISH228's Avatar
Just a question about the type of fluid you put into your car. I heard that the Nissan Tranny Fluid has special chemicals that was made for Nissan vehicles. By changing the fluid, this will void the warranty. Anyone have opinions?
Old Mar 30, 2004 | 10:26 AM
cobymoby's Avatar
False. Just use approved fluid and you are fine.
Old Mar 31, 2004 | 02:21 AM
I've done my ATF flush today, the DIY is easy. I've got 9 quarts out of the transmission. Very pleased with the result. The DIY How-to with pics will be posted on my cardomain site in a couple weeks, want to help everyone save some bucks.
Old Mar 31, 2004 | 02:26 AM
Also Thanx Jime, your write-up is very detail. There is one small difference within ur writeup, the Trans fluid did not come out slowly through the fuel line, it came out so quick and the funnel couldn't take the dirty ATF at that speed, and spilled all over on the ground. It took me 1 hour to clean the grease off. I still love the mess, coz i learned something. Thanx Jime
Old Mar 31, 2004 | 02:50 AM
steelymatt's Avatar
Did you wind up using synthetic? Can you feel a difference?
Old Mar 31, 2004 | 03:06 AM
I only did a 2 min test drive, can't really tell the difference. I use Redline Synthetic ATF, quite expensive stuff.
Old Mar 31, 2004 | 04:23 AM
Jime's Avatar
I didn't say to use a funnel, just stick the hose directly into the top of the plastic container. Guess I should have been more specific.
BTW I just did mine last nite on the 2k2 and did a cooler install at the same time.
user 11122324
42
Jul 18, 2022 03:35 PM
Forge277
Jun 13, 2016 09:26 PM
fastcarny
Oct 12, 2015 07:06 AM
markevans999
Sep 10, 2015 04:29 PM
