body oil on paint PICS!!!!
Old Apr 3, 2004 | 02:05 PM
ZIPPIN's Avatar
Mauja He Mauja
as the pic shows, finger marks on the paint. i have tried the clay bar and wax,,,even got the car professionally done and they are still there...
help!!!!!!!!!!!!!!!!!
Old Apr 3, 2004 | 02:12 PM
2k3TitaniumSe's Avatar
I don't know. Try the detailing forum here.
Old Apr 3, 2004 | 02:19 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
What's on the car?? Oil or some type of hand lotion???
Old Apr 3, 2004 | 02:24 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Have you tried a polish like Menzerna?
Old Apr 3, 2004 | 04:16 PM
ZIPPIN's Avatar
Mauja He Mauja
it is just finger marks. i did post it in the detailing section. no ideas though
Old Apr 3, 2004 | 04:32 PM
MaxSE03's Avatar
First time i've seen this problem. Did you try any compounds like 3M fine cut or Meguiar's #2? They should take care of it. If not, here is a link to a good but low price circular polisher:
Vector
Old Apr 3, 2004 | 04:37 PM
ZIPPIN's Avatar
Mauja He Mauja
the one on the frnder is from me doing something in the bay and putting my hand on the fender. now i use a cloth when i work in the bay. i am going to get the craftsman" don't know what it's called, but you place it on the fender to prevent elbow grease on the paint" i have scrubbed it like there is no tomorrow and it does not come off.
Old Apr 3, 2004 | 04:48 PM
redstradic's Avatar
i would get some 3M fine rubbing compound! it will remove it. just wax the area once you are done.
Old Apr 3, 2004 | 04:50 PM
ZIPPIN's Avatar
Mauja He Mauja
is there a certain kind? can i get it at wally world or autozone??
Old Apr 3, 2004 | 04:51 PM
MaximaPolak's Avatar
Looks Like Someone Touched the Paint When It Was Still Wet and Then Clear Coated It. Need to wet sand to see if i'm right. If so, Repaint those parts
Old Apr 3, 2004 | 04:56 PM
ZIPPIN's Avatar
Mauja He Mauja
this has happened in the last few months. the ones on the fender happened last month when i was recharging the K&N. i am surprised that the detail place couldn't get it off....
Old Apr 3, 2004 | 05:06 PM
Zero Deuce SE's Avatar
You must be talking about a fender apron/cover.
http://shop.store.yahoo.com/rodi/epp5436.html
http://www.gppinc.com/products/produ...5&categoryId=9
Old Apr 3, 2004 | 05:10 PM
redstradic's Avatar
its just 3M rubbing compound. its in a black bottle and i would get about a 1200 grade or higher. i picked mine up at Autozone. i did the same thing except mine was from grease when i was changing out my suspension and the rubbing compound was the only thing that would remove it.
Old Apr 3, 2004 | 05:11 PM
ZIPPIN's Avatar
Mauja He Mauja
Originally Posted by charliekilo3
yes..this is exactly what i need to get. thx for the info
Old Apr 3, 2004 | 05:40 PM
ZIPPIN's Avatar
Mauja He Mauja
thx i will try that tomorrow. i love sunday's....
Old Apr 3, 2004 | 06:16 PM
itdood's Avatar
For any kind of clear coat work, the most course you should go is a 2000 grit (any brand will do) and work up finer. 2000 grit will get swirls out of the clear coat, so it may work on those clouded areas.
You can get 2000 grit paper and wet sand. Or you can get 2000 grit polishing compound and use a buffer. Be careful of edges and bumps because you will take the clear coat off of those areas if you work them too hard.
I use a 2000 grit polishing compound for stuff like that and it works like a charm.
Old Apr 4, 2004 | 01:40 AM
LAPI13's Avatar
I know this will sound funny but DAWN dishwashing liquid. It cuts grease, My dad has a Black vehicle and it had a greasy hand print that wouldnt come off all the way. I rubbed it with dawn and got the greasy part to break up and just washed the vehicle the same old way. I got the idea from the tv and it worked. I dont wash my car with Dishwashing liquid, but it worked.
Old Apr 4, 2004 | 01:48 AM
Chinkzilla's Avatar
Dawn works wonders.. try that before you go cutting up your clearcoat.
Old Apr 4, 2004 | 06:43 AM
hotrod37's Avatar
just make sure you put a good coat of wax over the area you washed with dawn. It will strip all the wax off the car
Old Apr 4, 2004 | 06:55 AM
Did you have sex by your car after doing the K&N Refill without washing your hands? This is weird to me how this can happen and you can't take it off.
Old Apr 4, 2004 | 06:59 AM
ZIPPIN's Avatar
Mauja He Mauja
i have before, but it was the other fender
,,no grease there...
Old Apr 4, 2004 | 07:03 AM
Doin' the nasty on the car is ok......but wash your hands before you do.
kjlouis
Oct 3, 2015 05:29 AM
97_GXE
Sep 15, 2015 06:47 AM
ag90fox
Sep 9, 2015 12:22 PM
Hdnseek
Sep 9, 2015 05:55 AM
videomano
Sep 8, 2015 03:28 PM
