Where can I get a MAF sensor?
Old Apr 6, 2004 | 09:52 AM
JoeJoe's Avatar
Sorry Guys, search won't work for me for some reason. Anyways, I need a new MAF sensor. Where can I get one and how much should I expect to pay? Thanks for your quick responses. I gotta get this baby fixed by tomorrow.
Old Apr 6, 2004 | 10:00 AM
2002 Maxima SE's Avatar
What is it doing? Did you try cleaning it?
Old Apr 6, 2004 | 10:04 AM
JoeJoe's Avatar
My car chokes out at about 2000 rpms. The shop I took it too just said I need a new one. It can be cleaned? How much is a new one?
Old Apr 6, 2004 | 10:12 AM
Cubanato's Avatar
Joo wanna play??......ok we go to war
does it go past 2000 RPMS???
you can get a new one from DaveB for aobut $88 plus shipping
his number is 1 888 254 6060....just tell him your from the org and what you need
-J
Old Apr 6, 2004 | 10:16 AM
Yes, and its a lot cheaper than buying a new one if it works.
1)Unscrew MAF with security torx bit.
2)Using a Q-Tip and some rubbing alcohol/brake cleaner gently wipe the filament looking piece. (Looks like the inside of a light bulb).
3)Reinstall and test.
Total cost: $0.00
Old Apr 6, 2004 | 04:55 PM
ckohl23's Avatar
is that safe? what thread/website did you learn this procedure from?
i don't get why people are replacing their MAFs if cleaning it is really that easy.
Old Apr 6, 2004 | 05:17 PM
Cubanato's Avatar
They replace them becuase they blow....which means you cant clean them because they dotn work anymore
-J
Old Apr 6, 2004 | 05:32 PM
Been doing it for years on every car I own. With the Maxima, sometimes you can clean it and sometimes it is beyond repair. For some reason, everyone on this site goes straight to buying a new one without trying.
Old Apr 6, 2004 | 05:36 PM
-J
How many have you tested? What was the current being sent before and after? What code was in your ECU?
MAFs do not "blow" like a bomb. A MAF can get oil/dirt on the filament which will interfere with the signal being sent to the ECU...its that simple. Clean it and test it, if it doesn't work then replace it (there was something else wrong with it).
Using your logic:
I guess you replace your car when you have a flat.
Old Apr 6, 2004 | 05:39 PM
Cubanato's Avatar
Using your logic:
haha real funny .....when you "BLOW" an MAF then you can talk
they dont make a sound like KABOOM....this i know...but they blow in the sense they dont work
when your SES light comes on and ur car doesnt rev over 2200 RPMS...teh MAF is beyond cleaning...becasue it doesnt function anymore
so please dont TALK when you CLEARLY dont KNow
-J
Old Apr 6, 2004 | 05:42 PM
-J
Funny how you're the one "blowing" MAFs and I'm running just fine. If your car sends a "Check Engine", I guess that means it's time to replace it. You must work for Nissan.
Old Apr 6, 2004 | 05:45 PM
Cubanato's Avatar
Funny how you're the one "blowing" MAFs and I'm running just fine. If your car won't run, I guess that means it's time to replace it. You must work for Nissan.
funny....i dont think its funny that NISSAN buys cheap MAF sensors
and alot of people have "blown" MAFs numerous times
so maybe you shoudl replace your atttude
-J
Old Apr 6, 2004 | 05:47 PM
-J
Aside from you making more of an *** of yourself...how does it hurt to clean it before committing to the replacement? If you don't have the technical ability, just say so.
I'll pose my questions again that you bypassed:
Old Apr 6, 2004 | 05:49 PM
Cubanato's Avatar
i new it didnt work because i have the technical know how
and obviously you know nothing but how to clean things.....ooohh cleanign it will help it work
but this stupid argument ends here....get over urself
remember who tried to be a smartass 1st ...<YOU>
-J
Old Apr 6, 2004 | 05:51 PM
-J
The conversation ended when you spoke. Be sure not to clean your throttle body, injectors, or air filter...your car will be the shizzle.
You still didn't answer my questions. I guess your "skills" don't go beyond "Mom, buy me a new sensor."
Old Apr 6, 2004 | 07:11 PM
ZIPPIN's Avatar
Mauja He Mauja
oooh thats LOWWWWWWWWWWWW!!!!!!!
Old Apr 6, 2004 | 07:17 PM
KLOOGY's Avatar
L33t BMW Drivah
2002 Maxima SE, you are acting like a child....and many of us have blown Maf's ...so easy there mr NismoWrench.....
Old Apr 6, 2004 | 08:48 PM
ckohl23's Avatar
woohoo my simple comment started a flame war...come on guys this is a simple difference between maintenance and repair, although i agree that it doesn't hurt to try cleaning the MAF sensor before replacement. that is all...
Old Apr 6, 2004 | 08:59 PM
mikelly's Avatar
This cleaning method works fine but I use air compressor and it did the job for me.
Works great.
Mike
Total cost: $0.00
Old Apr 7, 2004 | 03:48 AM
My point exactly.
Old Apr 7, 2004 | 03:50 AM
Its pretty obvious you're going to ignore the insults hurled by 2k2whitemaxi, so I won't try to reason with you.
By asking what his "technical skill" was for testing the MAF....I am hardly child. If it saves someone $80 - $100 for a new MAF, I'll gladly be the one to inject reason (attempting a $0 solution) into the argument (replacing a part).
As I said in my first post, there may be other problems with cause for replacement but there is nothing lost by attempting a cleaning.
Old Apr 7, 2004 | 04:46 AM
Jime's Avatar
Here is what I do, got this from a VW site and have used this procedure for 2 years now and it works great.
I don't think it is a good idea to physically touch the MAF sensor with anything other than Isopropyl Alcohol. I have cleaned mine a few times by putting it in a large ziplock bag and filling it up with Isopropyl Alcohol (99%) so that about 1/2 of the MAF is submerged. Then I shook it up and transferred it to another ziplock bag and repeated the process. Then let it air dry.
Old Apr 7, 2004 | 04:57 AM
zman187's Avatar
where do you get isopropyl alcohol?
Old Apr 7, 2004 | 05:02 AM
Jime's Avatar
Any Drug store/Pharmacy, make sure its 99% not the 70% stuff.
Old Apr 7, 2004 | 05:21 AM
ZIPPIN's Avatar
Mauja He Mauja
or you can use EVERCLEAR
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
