Can someone post a pic of how their Berk intake looks in their 2000-01?
Old Apr 6, 2004 | 05:55 PM
sascuderi's Avatar
Going to install the Berk this weekend. Would be helpful to me if I could see some picks of how it looks in the 00-01 Max before I begin.
Thanks!
Old Apr 6, 2004 | 06:14 PM
CCx's Avatar
CCx
Old Apr 6, 2004 | 06:36 PM
sascuderi's Avatar
Why do you have the MAF pointing down?
Old Apr 6, 2004 | 06:57 PM
CCx's Avatar
CCx
Because I'm an idiot I was in a hurry when I installed it and that's just how it turned out. Once it gets warmer out I'm gonna turn it around, makes no difference either way, wire's long enough to reach it just fine.
Old Apr 6, 2004 | 07:02 PM
ZIPPIN's Avatar
Mauja He Mauja
do u live in alaska?? i changed the brakes, pvc valve, antifreeze, oil, washed her, changed plugs 3 times, and i live in indy..freakin cold here!! down some tequila and get to work j/k
Old Apr 6, 2004 | 07:05 PM
CCx's Avatar
CCx
LoL, did my intake, brakes, pcv valve and two oil changes this winter, but that was all on the days it was unseasonably warm Now that it's staying light out later I've got a basement full of mods and general maintenance items that need attention.
Old Apr 6, 2004 | 07:08 PM
sascuderi's Avatar
Oh. One other question, does the intake move around alot when the engine is running, and does the bracket which goes to the intake secure it enough?
(also, how do you like it?)
Old Apr 6, 2004 | 07:36 PM
CCx's Avatar
CCx
Yea, the bracket secures it fine - it's not attached in the picture, but it is now, I have it tightened down on the intake, but not totally tightened on the strut tower to allow for a little movement - no it doesn't move around a lot at idle...wouldn't know about at WOT because I'm usually behind the wheel and not in the engine bay...
I love the intake, it roars above 3,500 RPM, you'll enjoy it!
Old Apr 6, 2004 | 08:42 PM
redstradic's Avatar
Old Apr 6, 2004 | 09:24 PM
5 spd's Avatar
I really need to clean my engine bay
Old Apr 6, 2004 | 09:26 PM
scopium
check website
Old Apr 10, 2004 | 02:27 PM
sascuderi's Avatar
Ok, got mine in last night. Here are two picks:
http://www.scuderi.net/car/
My impresion is positive for the most part. I notice quicker throttle response, very nice growl on acceleration, no loss of low end power that I can tell, quiet on idle and crusing, and the whistle on moderate acceleration. Only the whistle I'm not too sure about.
Overall, the car feels like it has more "life".
Thanks to those that posted a pic, it helped with my install.
Old Apr 10, 2004 | 04:19 PM
Shift_VQ's Avatar
i just bought a berk mid pipe to replace my frankencar but my frankencar had a hole in it next to the big tube for something and my berk doesnt...what do I do?
Old Apr 10, 2004 | 04:26 PM
sascuderi's Avatar
Not sure what you mean.
My Berk mid-pipe has a long tube coming off the side with three spots to connect the rubber tubes to. Everything fit fine.
Old Apr 10, 2004 | 04:35 PM
Shift_VQ's Avatar
my frankencar had a hole in it next to the main tube...i'll try to find a pic of a frankencar pipe or someones set up
Old Apr 10, 2004 | 04:46 PM
sascuderi's Avatar
Pic would be good, but what did you use the hole for? Was it just open to the air?
Old Apr 10, 2004 | 06:53 PM
Jackboot's Avatar
the hole is for the air temperature sensor I think. its the thign that is stuck in the scoop.
Old Apr 10, 2004 | 10:01 PM
cobymoby's Avatar
That is correct. It should stay there.
Old Apr 10, 2004 | 10:14 PM
Jackboot's Avatar
I put mine in my frankencar, i took the scoop off my car... doesnt really make a difference...
iflexsteel
Sep 15, 2015 03:37 AM
soloist3
Sep 2, 2015 12:59 PM
A32goldylocks
Sep 2, 2015 06:39 AM
halfpol
Aug 5, 2015 08:24 PM
