Foglights Help !
Old Aug 22, 2000 | 10:40 PM
Max2K's Avatar
Can someone tell me wat type of foglights the 2k maxima uses. Is it the H3 55W and i want to know how to install them cuz the manual doesnt show u. And since there is no clear corners for the 2k maxima does anyone know where to get white or red bulbs for the blinkers. Finally I was wonderin how the mileages r for the all the new 2k maxima. So far im gettin pretty crappy EPA for my maxima, only gettin around 20 for drivin both freeway and local !!!!!
Thanks ~
Old Aug 22, 2000 | 10:48 PM
kafene's Avatar
the fogs are h3
i just installed some today as a matter of fact. i rotated my tires, cleaned my k&n cone filter, and installed the fogs all under 2 hours! whew!
as for the blinkers, aren't they already clear? i also have a 2k max (se)
Old Aug 23, 2000 | 06:08 AM
yongjun's Avatar
aight
i went through hell installing fog light bulbs in my 2k max.
i had to get help from russ and kev.
but here we go
if this doesn't help message me on aim and i'll see what i can do.
aight climb under the front end of your car.
remove all these little black plastic screws and some reular screws.
this should allow the front splash guard to come off
look under the foglight
there should be one screw.
take that out.
then force the whole fog light unit out.
replace the bulb just like the headlight.
then do reverse steps and you should be set.
don't forget the replace the screws =)
Old May 8, 2005 | 09:29 AM
04BlackMaxx's Avatar
That dosent sound too difficult
Old May 8, 2005 | 09:52 AM
LA02MAX's Avatar
http://www.innerbean.com/housecor/piaa_fogs.html
it is NOT hard at all...and btw, the 'corners' can be cleared on a 2k max, but the blinkers within the headlight are already cleared, so i would suggest getting a chromed amber bulb to stay legal and retain the clear look..
Old May 8, 2005 | 09:55 AM
Puppetmaster's Avatar
Guys... the last post before today was 08-23-2000, 09:08 AM....
Old May 8, 2005 | 10:41 AM
RP300zx's Avatar
Fog Lights
My fogs are not working, the i am checked all fuses and im getting current all the way up to the relay under the hood, I am guessing it might be because one of the fog bulbs is burnt out. Any feedback????
Old May 8, 2005 | 11:40 AM
Its funny noone noticed this is a classic 5th gen thread
Old May 8, 2005 | 11:43 AM
Um... what's your point? I'm not sure I understand.... since you're the one who dug it up....
Old May 8, 2005 | 01:27 PM
What's your point that this thread is from 2000? Foglights are still the same, right?
Old May 8, 2005 | 01:30 PM
My point was that the discussion had ended 5 years ago and it appeared to be a pointless bump saying "That dosent sound too difficult" but then again, maybe you were trying to accomplish something, maybe not, that's why I asked...
Old May 8, 2005 | 01:33 PM
SoonerFan's Avatar
Cletus
way to pull up old posts...IN THE WRONG FORUM
this is yours http://forums.maxima.org/forumdisplay.php?f=66
Old May 8, 2005 | 01:44 PM
I dont mind previous gen. owners posting in the 6th, it happens all the time..no one really cares...but if its the other way around SOME people get their panties all in a knot...i dont know why.
Old May 8, 2005 | 02:41 PM
SoonerFan's Avatar
Cletus
the problem is...since nothing happens in the 6th gen forum, you come in here just to post ***** and talk ****. you dont have a single helpful post in the 5th gen forum.
Heat0212
Oct 24, 2020 12:36 AM
ricky7780
Nov 3, 2015 03:22 PM
Excalibur23
Oct 13, 2015 04:33 PM
Hdnseek
Sep 9, 2015 05:55 AM
fc95se
Nov 15, 2000 05:14 AM
