LED lights in the window and lock switches
Old Apr 9, 2004 | 09:17 PM
SE4KIMMY's Avatar
How Do I go about changing my LED lights in my switches, I have already done the drivers side switches and I am now having trouble with the passenger and rear switches.I am simply changing the color. Does anyone have instructions? Any help would be great!
- Kim
Old Apr 9, 2004 | 09:33 PM
JCmaxse00's Avatar
there is a post below titled"Anyone changed ash tray light cover".. go there , there is a write up about it. i couldn't figure how to post it here so hope u find it.
Old Apr 9, 2004 | 10:06 PM
custommaximaSE's Avatar
http://www.cardomain.com/memberpage/526558/4
Old Apr 9, 2004 | 10:46 PM
Kojiro_FtT's Avatar
Originally Posted by custommaximaSE
That's not a very descriptive write-up. What about the "loose copper connectors and ball bearings inside" that Alex's write-up mentions? How did you disassemble/reassemble?
thomasd cook's Avatar
Check my homepage also for a write-up.
Old Apr 10, 2004 | 01:07 AM
stevay's Avatar
there was a nice writeup here for a 4th gen.... dont know if same applys to 5th http://www.cardomain.com/id/redmax99sel i believe its on the 4th or 5th page
Old Apr 10, 2004 | 09:27 AM
irish44j's Avatar
retired moderator
couldn't you just use a sharpie of a different color and color the light opening on the switches...wouldn't that have the same effect without so much work?
Old Apr 10, 2004 | 12:52 PM
Won't be 1/3 as bright as the LED's.
Old Apr 10, 2004 | 01:01 PM
MaximaPolak's Avatar
It's EZ. My rears are blue but front are stock green.
Old May 8, 2004 | 04:40 PM
irish44j's Avatar
retired moderator
so if it's so easy, would you care to share with the rest of us how you did it?
Old May 9, 2004 | 04:12 PM
MaximaMan77's Avatar
I did my rears very similar to thomasd except I used the rubber mount for the LED and turned it upside down and attached the LED and resistor to it. I used 300mcd for these. They are Plenty bright!
The fronts on the 02+ are SMT LED's soldered to the circuit boards as seen on his page. You can find these LED's here
For 20 bucks you get 15, enough to do 2 cars with 1 spare.
You'll need 2 low watt soldering irons (not guns) and a helper to get the old ones off. Have the helper hold the SMT with a needle nose and lightly pull while you heat up both sides. Then carefully solder the new ones down, there is usually still enough solder on the board that you won't need to add any. I couldn't find any polarity info on these so using some wire, a resistor and a 9V battery... When you look at the lens of the SMT you'll see the internal contacts almost make an arrow. The way the arrow points is +Positive and all of them point one way on the board, towards the front of the car the way they sit in the door.
I had the front done in a 1/2hr. The rears actually took a little longer.
I did the Auto temp control yesterday with 6000mcd, and I'm waiting on a cluster bezel before I do the rest of the dash. I also have 3mm & 10mm 6000mcd on the way. All LED's I used were blue. I plan on doing the radio, clock and Auto Temp read out with blue film like irish44j. I'm going to see how clear report covers that are blue tinted work.
****Disclaimer****
If you've never soldered before this may not be for you. Fine soldering is an art, not hard to learn but practice is needed.
You can get every thing you need at Radio Shack to do this. Also, Remember soldering guns are for soldering wire and crap like that, they carry a charge that can fry static sensitive stuff. Low watt irons are for LEDs, circuit boards and so on.
vingodine
45
May 21, 2016 12:46 PM
kmitchel
Oct 28, 2015 09:46 AM
Shock_and_Awe
Aug 23, 2015 01:02 PM
shaunkey1
Aug 18, 2015 10:09 PM
kjm900r
Aug 5, 2015 07:14 AM
