How to Remove MAF?
Old Apr 10, 2004 | 09:21 AM
cabernet's Avatar
How to Remove MAF?
OK, I've read through the threads and everyone makes it sound so easy to replace the MAF. On my 2K it looks like it's impossible to remove the lower 2 bolts holding the MAF to the filter housing. There's no way to get a wrench or socket underneath. So do you need to remove the entire filter housing first and then remove the MAF? Hard to believe it can all be done in 10 minutes. Thanks for your help.
Old Apr 10, 2004 | 10:55 AM
PhxBlue's Avatar
MK3 Supra and Focus ST
Are you trying to remove the whole tube or just the sensor? All you need for the sensor is a torx style screw driver and it comes right out the top.
Old Apr 10, 2004 | 11:20 AM
cabernet's Avatar
The new part I have has the tube with the sensor in it so I'd like to replace the assembly. It may be easier to remove the sensor from the new one and put it in the old assembly.
Old Apr 10, 2004 | 11:22 AM
PhxBlue's Avatar
You dont need the tube, just replace the actual sensor.
Old Apr 10, 2004 | 11:24 AM
Progress's Avatar
It's business time.
The easiest way to do that is to pretty much remove the whole airbox. You'll probably have to take the accordian-like tube off the throttle body.
Old Apr 10, 2004 | 03:30 PM
cabernet's Avatar
Just finished taking out the sensor and leaving the original tube. Easier said than done. First trick is to find the specialized driver head to remove the OEM screws (the newer ones can use a standatd T20 driver). After trips to 2 stores I found one - its called a security T20 head. Then the sensor didn't want to come out very easier. Took some twisting and pulling for a few minutes but finally popped out. I would have saved some time taking out the airbox but next time it will be quicker. Car idles much better and pickup is better too. Am testing MPG now. Thanks for all your help.
Old Apr 10, 2004 | 06:56 PM
spirilis's Avatar
yep, I bought a set of tamper-proof Torx bits from Advance Auto for $10... the T-20 tamper-proof Torx bit worked with mine (took it out for cleaning)
Old Apr 12, 2004 | 05:48 AM
schmatt's Avatar
If you want to replace the whole MAF assy, you will need to remove some of the bolts connecting the air intake assy so that you can wiggle it around. You don't have to remove the whole thing. It definitely takes a little longer. If you are only going to replace the sensor, then I would also suggest cleaning the screen in the MAF assy. This can be accessed by removing the air filter.
I replaced the whole MAF assy a few days ago. It was kind of a pain, but the screen in the original was pretty dirty.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
