Battery question
Why did you have to top it off to begin with? Alot of batters are maintenance free batteries which means you dont need to add water.
Was it working before? If so, there is no reason why it would stop after adding some distilled water. If the battery didnt hold charge before topping it off, then I bet the plates are screwed because of sediment.
Dixit
Dixit
Dixit
Dixit
Yes, the OEM battery is not maintenance free. You'll find that in general, if you keep a watch on battery level a non-maintenance free battery will last far longer than a maintenenace free battery. My guess is that maintenance free batteries still lose water but at a much lower rate. But since you can't add water eventually the level goes low and the battery dies. For me, it's worth checking the level every month or two (if you have to add more freqently your battery charging system is not working right or the battery's on its last legs anyway).
As for your dead battery a couple possibilities. If you let the water level go real low you damaged the battery and adding more water was the "straw that broke the camel's back".
Other possibility is you contaminated the battery while filling it. Before filling or checking always clean the area around the battery caps. I even use a little spray cleaner like 409 or Fantastic with a paper towel. Then take the caps off and wipe again in the areas covered by the cap. Wipe in a direction AWAY from the holes. Then use a clean funnel to add water with a mininmum of spillage. Any water on the top of the battery has a chance to be contaminated and then wash back into the hole. It doesn't take much contamination to defeat the whole point of using distilled water.
I went and bought a new battery and everything is fine now. When I took the old one out, I noticed that one side was buldging out quite a bit, so there is a problem. Not sure what caused it though, probably a short between the cells.
The Frye
Sep 2, 2021 11:03 AM
markevans999
Sep 10, 2015 04:29 PM
