Rev's Bouncing
Old Apr 16, 2004 | 03:19 PM
MauiMaxima's Avatar
Rev's Bouncing
Hey...this is a weird one that I've not seen before. Long story short, my idle usually sits at 1/2k but recently its been boucing from 0!!! up to 1.2K It will stall several times a day but start right back up. Any ideas?? Thanks!
It started when my check engine light went on but that was bad O2 sensor which has been replaced.
I would love some ideas before I take her in.
Old Apr 18, 2004 | 06:06 PM
MauiMaxima's Avatar
Well, if no one has any bright ideas on why my max would stall out...I guess its time to bight the bullet...bummer
Old Apr 18, 2004 | 06:51 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
if i had to take a guess out of the dark which can be a bad idea, it would be ignition coils. 2k and early built 2k1 are notorious for failing coil(s). was the ses light on?
Old Apr 19, 2004 | 11:21 AM
MauiMaxima's Avatar
The SES light came on earlier in the year but that was for a bad O2 sensor...those are fixed but this problem still remains.
You have any idea on the $$ for the fix?
Old Apr 19, 2004 | 01:20 PM
VMaximus02's Avatar
Aside from the ignition coils, dirty throttle body(stuck throttle plate) could be the problem too...try cleaning it out? Also, dirty fuel injectors will cause the idle to flucuate...so get a bottle of B&G44k and dump it in the gas tank.
Kojiro_FtT's Avatar
Wouldn't he throw a misfire code for a coil?
My guess would have been crankshaft sensor. Sounds just like what happened to my GFs Intrigue. I replaced the crankshaft position sensor and it's as good as new. A sensor will cost you anywhere from $30 to $90 depending on the store and brand. OEM obviously costs more.
Old Apr 20, 2004 | 02:13 PM
MauiMaxima's Avatar
sweet, thanks guys....I'll check it out and let you know how it goes.
02PearlSE
Feb 1, 2016 12:37 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
JoshG
51
Sep 21, 2015 10:41 PM
