LED Side-Mirrors from SWA, need a "How TO"
Old Apr 16, 2004 | 03:41 PM
maxima0002's Avatar
Hey all,
Going to purchase the LED side Mirrors from SWA. But before I do so, I need to plan my route with the install.
Does anyone have a detailed write up on how to install these, mainly the wiring job and whether I should go thru the firewall to wire the LEDs or thru the Rear signals instead ?
Thanks all!
maxima0002
Old Apr 16, 2004 | 09:20 PM
ICULookN's Avatar
I've been looking for a "how-to" for awhile, Bigdogjonx suggested wiring it to the turn signals behind the guage cluster. Does anyone know the color of the wires for the turn signals behind the guage cluster? I will try this on Saturday or Sunday, depending on fast I get a response.
Old Apr 16, 2004 | 10:30 PM
maxima0002's Avatar
Can ANYONE give us a How-To or even moderate install instructions? PLEEEEASEE!
Thanks to Bigdogjonx, but I haven't the faintest idea which wire to splice into behind the gauge cluster.
thanks to anyone who replies...
Old Apr 17, 2004 | 01:59 AM
custommaximaSE's Avatar
Thats all i find on the web.Its not help full with out pics,but you will get it.
LED Side Mirror Instructions
1. Remove Door Panel
a. Remove trim around door handle
b. Remove bolts on bottom of door
c. Remove bolt from bottom of cup by the window switches
d. Remove window switches
e. Lift panel upwards
2. Remove plastic cover on inside of door covering mirror bolts.
3. Pry mirror from housing by inserting a flat screwdriver underneath the mirror and prying up.
4. Remove screws holding back of mirror housing.
5. Remove bolts on inside of door holding mirror housing to door frame.
6. Remove screws underneath mirror housing.
7. Place new side mirror shells over existing shell (do not remove backing from double sided tape yet), running the wire between the tabs closest to the door.
8. Run the new wire through the housing towards the bolts, running it through the groove on the bottom of the housing, making sure that nothing will get in the way of the mirror folding in and out.
9. Finally, poke a hole in the foam material in between the bolts where the new wires should be coming through.
10. Connect the wire to the provided plug.
11. Run extension wire down the door, inside the plastic cover to come out through the rubber grommet closest to the car, following the bundle of cables to enter the car through another rubber grommet.
12. There are three wires, red, blue and black. The black goes to ground, the blue one you need to tap into your turn signal and the red one is for constant power.
13. To tap into the turn signal, extend the blue wire through the firewall out to the turn signals. Tap into the non-black wire.
14. You can have the red wire going to a constant power source with a switch in between to have them on at all times.
14. The ground you can ground anywhere underneath the console.
15. Test the turn signals to make sure everything works.
16. Replace stock mirror, leaving just enough wire to make sure the new shell will fit on. (Test a few times before double sided tape is exposed)
17. Remove backing from double sided tape and put new shell into place.
18. Re-install mirror and door panel.
Or you can check this site its for 2001 Impreza RS:
http://www.subiegalracing.com/images...ed_install.htm
Old Apr 17, 2004 | 08:08 AM
maxima0002's Avatar
THANKS for the reply custommaximaSE. True, no pics, cannot visualize, but better than nothing!
have a good one..thanks again
if anyone else has a link or instructions, please post..!
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
