Under Drive Pulley Question
Old Apr 19, 2004 | 12:57 PM
Tim01MaxSE's Avatar
Hey guys im thinking of putting an underdrive pulley on my 01 Max Se 5spd....Are they worth it...will i notice a difference in 1/4 mile and on street?? and what kind should i get and will it hurt anything thanks for any help TIm
Old Apr 19, 2004 | 07:02 PM
theMax's Avatar
I like mine and I'm an auto. You should get better gains.
It helps at the low end. I have much better pull off the line.
Once the car gets up to speed, there is not much difference.
I would reccommend.
Old Apr 19, 2004 | 07:12 PM
irish44j's Avatar
retired moderator
I think what he means is....."with everything that has an advantage come some kind of disadvantage, in theory. What are the advantages and disadvantages of an UDP, and which is the best one."
Old Apr 19, 2004 | 07:36 PM
bigdo26's Avatar
i have an UDP on my 2k2 auto and I like it. helps low end... go for it!
Old Apr 19, 2004 | 10:06 PM
Tim01MaxSE's Avatar
what kind do you guys have.....should i go with the unorthodox underdrive or is there another one out there that is better
Old Apr 20, 2004 | 12:24 AM
custommaximaSE's Avatar
well thing again about it .Check this site and read every thing .
http://www.motorvate.ca/mvp.php/521
So its good and bad on the other hand.And you ask what kind are they(there is 15% 20% 25% 30%).
Old Apr 20, 2004 | 01:42 PM
Tim01MaxSE's Avatar
Well i read that info( thanks bye the way) and i dont have a big stereo only 3 tvs but there hardly on.....so im thinking ill try it what should i get the 15% or the 20% thanks Tim
Old Apr 20, 2004 | 02:57 PM
bigdo26's Avatar
I have the Unorthodox UDP. Worked fine, no problems at all. Also have 2 subs in the back, RMS power around 350 watts (I think, might be more). Never any problems with powering them, even while running the AC in the summer. Also its great to get rid of the AC lag!!! Engine revs up more easily while using the AC
Old Apr 20, 2004 | 05:25 PM
GreekMaxima's Avatar
i got DMS UDP (Group deal) for $120 shipped with belts too!! it is still at my home... i will install it after my vacation... about August i think!!!!!
Old Apr 20, 2004 | 05:36 PM
Ammi's Avatar
350 Detroit Muscle
Unorthodox here.
Old Apr 20, 2004 | 07:30 PM
Tim01MaxSE's Avatar
OK What Size???????????
Old Apr 20, 2004 | 07:47 PM
BlackBIRDVQ's Avatar
drag racing is for wussies
I got an Unorthodox UD pulley and I installed it along with my Fidanza flywheel so I can't tell ya if there is any gain from it.... but I can tell ya with both the car rocks, it revs up like crazy. Also I can't even tell my AC is on, sounds stupid but I think it even runs better with the AC on at some times ! ECU advances the timing when the AC is kicked on to compensate for some of that compressor drag. I've watched it on my scanner... base timing goes up a little.
Old Apr 20, 2004 | 07:51 PM
vqman
how much of a gain would you see on a dyno or at the track?
would it translate to 0.1 seconds in the 1/4?
or a slightly flatter torque curve? (with more low end torque?)
just wondering...
-vq
Old Apr 20, 2004 | 08:05 PM
VegasMaxima's Avatar
is this a good place to get the UDP.
http://shop.store.yahoo.com/southwes...ismaxunra.html
Old Apr 20, 2004 | 11:35 PM
get the 20%.
Old Apr 21, 2004 | 12:46 PM
Tim01MaxSE's Avatar
thats what i was thinking 20%.....hey another question what are some mods that i can do to this to gain horsepower and improve my quarter mile...my buddy has an M3 and im trying to keep up with him....i have a frankencar intake...and ill do the pulley...what else is there that i can do...i dont want to touch the exhaust and a supercharger is way to much..thanks guys
Old Apr 21, 2004 | 01:47 PM
nocsyn's Avatar
for starters get rid of the rims...that will help.....i have the unorthodox....i like it a lot...but for some reason when its cold sometimes i hear this whining sound...like it sounds messed up not a good whine....could be my fan belt but who knows....im goin to the track soon and ill post my times pc
Old Apr 21, 2004 | 01:58 PM
CCx's Avatar
CCx
Sucks that you don't want to touch the exhaust...a y-pipe will give you 10+ hp, easily the best bang for the buck for the 00-01's.
Old Apr 21, 2004 | 02:00 PM
theMax's Avatar
I have the UR pulley and have no problems using the AC with the stock stereo.
I would not trust my car to any other pulleys as some have had problems and damaged others cars.
I agree about the wheels, they look heavy, but you might get a little improvement in the low end that your lost with the heavy wheels.
Old Apr 21, 2004 | 04:36 PM
what year M3 ? Ditch the wheels for some light weight 17" Rota Subzeros or Volk TE37s :P Add a set of HS headers, remove main cat using a test pipe, repleace the midpipe with a cattman unit and use the stock rear muffler section. Throw on a UD pulley, Place Racing cold air, do a ECU timing advance at the dealer- ask for one of the techs if U can ask them a question... then ask them if for like 20 bux they wanna advance your ignition timing via the Consult by 2 degrees, U will have to use Premium gas -93 is best if U live in the midwest. If your 5spd this should pretty much make ur car as fast as a M3. If both of you are autos then M3 will own ya off the line cause I6s tend to produce alot of low end torque. I driven all kinds of M3s and I'm not a huge fan of them. Stock clutch will slip if driven aggressively, and head gaskets like to blow out alot also. Overall in the long run, Maxima will last alot longer and have far less mechanical problems. Plus BMW parts tend to be on a expensive side vs Nissan's. If your friend owns a current generation M3, then U need a turbo or a blower to keep up . No naturally aspirated Maxima will keep up with the new M3.
Old Apr 21, 2004 | 04:58 PM
irish44j's Avatar
retired moderator
tim......please! make your signature smaller...you're killing those of us in the stone ages with dial-up connections!
Old Apr 21, 2004 | 08:16 PM
Tim01MaxSE's Avatar
Yeah he has a 1997 M3 both of us are 5 spds///
Sorry...haha ill fix that
Old Apr 22, 2004 | 03:55 AM
it will be a drivers race if the M3 is stock vs moded Maxima. Reason M3s are good off the line is cause of their gearing. 5spd Maxima has very long gears compared to other cars. Should pull on him on the highway with no problem thou. I spanked a new M3 in my G20 week ago. Driver was ****ed but then asked me if I was NOS, I laughed and told him its a slightly modified SR20DET engine that comes stock with the car ( in JAPAN- but he don't need to know dat). Within a week the little red box walked a auto LS1 Vette like crazy, LS1 Camaro 6spd, EVO, new M3, old M3 and 2 Maximas. My Maxima is just my daily driver, I have other faster cheaper, more reliable cars
Old Apr 22, 2004 | 04:08 AM
maximamaybe's Avatar
I purchased the Motostorm one and I am very happy. It also still gives my amp plenty of power. I am running a 600 watt JBL and a 150 watt Phoenix gold with no voltage issues.
Old Apr 22, 2004 | 11:11 AM
Tim01MaxSE's Avatar
ok thanks guys...other than the stuff you listed any other engine mods i can do??
Old Sep 20, 2004 | 08:34 PM
from whre can i get power steering belt and a/c belt?
Old Sep 21, 2004 | 06:13 AM
juice's Avatar
Save your money..the udp is not worth the cost not the install. I have run at the track with the udp both installed and removed and I can tell you it will not make a difference. For almost the same price you can get a y-pipe and that will yield MUCH better gains
Old Sep 21, 2004 | 07:27 AM
Dave B's Avatar
Not DAVEB the parts guy
It was a waste of my money too. 14.4@98mph with the UDP and 14.4@98mph without the UDP. Also, the UDP introduced some grainy vibrations at both idle and throughout the rev range. The more I learned about UDPs, the more I've become convinced they don't do squat. For one thing, the stock VQ pulley has an elastomer ring sandwiched inside the pulley which is actually two piece pulley. This ring acts a torsional crank dampener. The UDP doesn't have this ring therefore more vibration is introduced. This vibration is more apparant on the smoother running 3.0 VQs than the 3.5 VQs. The VQ motor is a very stout powerplant and I don't think an UDP could cause a major failure like a broken crank, but the UDP can cause valvetrain timing problems due to the vibration of the crank and pistons. This can ultimately hurt power. If you really want to gain power, add a HEAVIER dampener. F1, stock car, drag cars, and most other race cars run rather heavy "fluid" dampeners that make the crank perfectly balanced which in turn improves valvetrain operation and gains power. You'll never see UDPs on these race cars.
Old Sep 21, 2004 | 09:19 AM
juice's Avatar
Another reason I removed my Unorthodox UDP. The vibration at idle...it made my tensioner pulley rattle like crazy...as soon as I removed it the was noise gone.
Old Sep 21, 2004 | 10:48 AM
bgates1654's Avatar
Pulley on the 02-03 is a single peice with no dampener. I paid $110 total (UR is a rip off) for my UDP/belts/install... what does a y-pipe cost? What about all the dyno proven gains? Drag times are subject to many many variables. It is estimated that 10hp will drop 0.1 off your ET. UDPs give realistically up to 5wtq gain throughout the rpm range with a 6.5hp peak on the 3.5 max. You will not see a change in tenths of a second with the UDP, more like 0.05... it is not a major mod. Where did you get this stuff about heavier being better? I have had my pulley for about a couple thousand miles now and I have seen no vibration or odd noises.
Old Sep 21, 2004 | 01:26 PM
bump
69-69-69
Old Sep 21, 2004 | 10:08 PM
Dave B's Avatar
How much you want to bet? Take a look at your old pulley and you'll see a thin (~1/8") black very high duramoter rubber ring sandwiched ~.5" from the outer edge of the pulley.
Here's a pic of a failed ring on a VQ:
http://forums.maxima.org/showthread....t=crank+pulley
http://www.popularhotrodding.com/eng...06mm_windsor2/
Since I many will not read the link, here's what they found out using the ATI Super Damper:
As RDI's Preston Miller points out, the ATI Super Damper is the overwhelming favorite among WC and BGN engine builders. Having a damper that really cracks down on torsional vibrations not only significantly extends crank life, but also adds power.
At first it may seem an unlikely piece of go faster equipment, but an effective crank damper cuts the amount of torsional vibration transmitted to the camshaft. In so doing it allows the cam to much more nearly deliver the intended lift/duration characteristics to the valvetrain. Forget light when it comes to dampers. Even for a drag racer, where acceleration is all that matters, a functional damper will out perform a light, non-functional one every time.
So how much power can a damper be worth? Forget about hearsay and some of the opinions of even well-known racers. Testing on my own dyno on a nominally 400hp motor showed a good damper was worth 5 hp over a typical factory damper (which was designed for the stock bottom end not a modified one) and over 11 hp over that delivered by a lightweight hub.
I can provide a ton more info if you still don't believe me.
Old Sep 21, 2004 | 10:50 PM
bgates1654's Avatar
I will check mine out when I get over to my parents house next time. I am fairly certain that 95 crank pulley =/= 02/03 crank pulley.
That article you posted is effectively saying that we should see less power with a UDP which is not true. There is obviously something entirely different going on there. Please provide more info.
Old Sep 22, 2004 | 07:08 AM
theMax's Avatar
bump
69-69-69
Go to your local auto parts store and ask for the size you need. I had to bring it back once to get a larger one so everyone may be a little different.
Old Sep 22, 2004 | 07:33 AM
00MaxSE's Avatar
Pointy Elbows
I also have the Motostorm UDP. It was $90 shipped in a GD. No problems whatsoever.
Old Sep 25, 2004 | 11:20 AM
Dave B's Avatar
As taken from Greg's 2k2 webiste, here's proof that the stock 2k2+ pulley does indeed have the same rubber ring as the 3.0 VQ. Oddly, Greg says there is no such ring even though the pic clearly shows the black 1/8" rubber ring ~.5" inside from the outside lip of the pulley. I think Greg needs to get his eyes checked
Old Sep 25, 2004 | 08:16 PM
irish44j's Avatar
retired moderator
Dave, do you know if there is a heavier dampener available for our OEM pulley by any chance? might be worth testing out the theory....
tsi6001
Oct 3, 2022 10:23 PM
Matt93SE
May 24, 2019 02:58 PM
02PearlSE
Oct 7, 2015 02:12 AM
kenc15
Sep 25, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
