so ya.. i totalled the max last weekend...
Just found out this morning that its "totalled" my insurance co wont spend the $$ to fix it.. over 12k in damage.. i hit a freeway median at like 60mph and ripped up the front end then the back end slammed into the median too and ****ed up the rear axle and both rims on the left of the car.. so now im looking for a new car.. have no clue what to get.. The only thing im gonna pull from the car is my hid's and most of the stereo and the strut bar.. so make some offers u vultures..
im out
Adam
im out
Adam
im out
Adam
im out
Adam
Originally Posted by Dee Dibease
You still have the SE tail lights? I will give you 150$. What the hell were you doing sleeping??. I think your next car should be a g35 coupe!
nah.. they are in pieces on the I17 i didnt fall asleep... i had to swerve and the car went way out of control..
Sorry to hear. It really concerns me to hear yet another example of someone with a RSB losing control of their car. It appears to be a common problem for RSB owners. The rear end get loose very easily and accidents occur. This is the second instance I've seen this month on the org...
Here's a pic of one doing just that. What to notice here is that the tire is off the ground, but the suspension is compressed. You'd expect with the tire off the ground that the suspension would be unloaded (there would be a lot of air between the tire and the wheel well like when you jack it up). The suspension is compressed because the RSB is doing its job, too well. IMHO, that's an indication the front and rear suspensions are not well balanced. In other words, beefing up the rear suspension more than the front, like when someone throws only a RSB on a maxima. The front can sway a ton, but the rear wants to stay tight, things end up not sqaure. Look how much this VW leaned up front.
Whoa whoa whoa WAIT A SECOND...
I totalled my maxima on 3-18 after swerving and losing control of the vehicle. I too had a RSB, I also had a FSTB as well... Are these sway bars doing more harm than help? Someone with insight, please make aware the dangers of these bars!
I started a poll at http://forums.maxima.org/showthread.php?t=304265 to gauge how common this issue is.
Maybe we could find out what kind of suspension set-ups the people in the pole have. Maybe it is a combination of cretain aftermarket shocks and springs and RSBs that are causing problems.
Originally Posted by NewLoveI30
For the most part people dont seem to be having a problem with this. I understand how if the bar were too stiff you would get some pretty nasty effects, but I would hope a lot of R&D went into producing these RSBs.
Originally Posted by IceY2K1
Adam,
What condition were your front compared to rear tires in?
Also, what psi front/rear do you normally run?
all 4 were fairly new with the fronts being more worn than the back.. they were nitto 450s all round.. i keep it at stock psi.. 35 i think
Damn...that eliminates that Motor Trend article as a possibility. JOo just don't know how to drive.
Pick out what color G35 you're getting yet?
i dont think im gonna get a g35.. im cheap now and dont care as much about cars.. ill probably get like a 2001 passat.. they are cheap and the 1.8t can be fun
Look guys, there are many different factors that could cause you to lose control. Let's not jump on a bandwagon and blame the RSB. First of all, the tires are what actually makes contact with the road. What were the condition of those. Apparently they were brand new. Do you know if the brand you put on have a good amount of friction to keep them from slipping? What were the road conditions at the time? Was there any amount of water? Just a damp road surface, not standing water, can dramatically reduce the friction coefficient between your tires and the road. Did you have stock suspension? Possibly the softness of the stock suspension with an RSB will actually set the critical point of having a tire lift off of the ground lower than with a stiffer suspension.
My point is that it was probably a combination of many things that caused these accidents.
ok here is how the accident happened.. i was in the far left lane and swerved hard.. when i did this the back end came out to the left and im now like 3 lanes over heading towards the right wall.. i corrected and the back end came out to the right and im heading to the left wall.. i correct again and im now pointing forward but still slam into the left median.. Im running semi new nitto 450 tires on HR springs with stock struts and a FSTB.. this is the first time i had the back end come out on me and once it did it was impossible to get it straitened out in the amount of space i had..
I've gotten the rear loose on all sorts of cars from trying to quickly avoid something at highway speeds, always managed to get straight again (luck).
They teach you in race driving school that if you get the rear loose at fast speeds to: "when in a spin, with two step in". In other words, if you can't straighten it out and it's coming around, LOCK UP THE BRAKES (both feet on the brakes as hard as you can)!!! Gives you somewhat of a chance to keep off the walls. If you don't lock 'em up, the car will just shoot in the direction it's pointed (usually a wall) when enough speed scrubs off and the tires hook again. If the tires are locked, it will just keep skidding in the direction of momentun which hopefully is straight down the road. I'm not sure if that will work with ABS.
This was not caused by your suspension set up, this accident has to do with weight transfer just keep in mind that our cars are very front heavy. Picture this; something happened to make 2000MaximaSE swerve, I'm sure he braked at the same time. What this does is transfers all the weight to the front left tire, so this tire has a ton of grip, and that’s why the car turns so tight, but also the rear tires now have little or no traction. So the car will then pivot around the left front tire. Now 2000MaximaSE is heading for the right wall and continues to break hard, then turns causing the same thing to happen in the opposite direction.
The nice thing about sports cars are that they are balanced, front to back, so when your in situations like this the car handles like it's supposed to. We are not blessed with this equation we have nothing but an empty back seat and an empty trunk (in my situation) over the rear wheels.
I know from experience that when I hit the breaks and turn the back end gets very slippery and again that’s because there is no weight over the rear when you are hitting the brakes.
The thing that I have learned about handling our car is to break in a straight line, then turn only if absolutely necessary and come off the brake when turning.
I don't want to sound like a know it all, and I have gotten into my share of car accidents, but if you really want to protect yourself and your car and become a safe driver try autocross. Mazda has one where you can use their car, or you can do SCCAII and use your own. There is no way to plan for emergency maneuvers but you can get practice at it.
2000MaximaSE sorry to hear about your loss but glad to hear your ok.
ha ha.. the fact i kept this car in one piece for almost 4 yrs is amazing to me
A site you might want to check out:
http://www.myvwlemon.com/
Good luck with your next car.
Originally Posted by 6spmax
If you're feeling cheap, stay away from VW at all costs.
That car is FUN to drive, though it doesn't have the torque of the max...and it's nice and roomy inside for a smaller car (much larger than the Jetta inside)...
People crash because they push their car further than it can go. I spun out going 90mph on an on ramp and spun into the 405 North (here in Cali) at 3PM in the afternoon, luckily it wasn't too busy and everyone on the freeway was able to avoid me and brake in time. I spun 2 1/2 times. Yes, I do have a RSB and it was my fault, not the sway bar's fault. I was being an idiot.
If you guys are worried about the RSB being too stiff then loosen it so that the mounting points are furthest out. Most people here, including myself have the thing adjusted for maximum stiffness which feels great for "spirited" street driving.
Just use your common sense and you'll stay out of trouble.
Skid recovery in a FWD car is an unnatural act - braking is exactly the opposite of what's needed, you have to stand on the gas. I had to learn this when I switched from racing RWD to FWD, an FWD car set up to handle well will rotate in a turn just with a throttle lift because of the weight transfer. This is a problem because your natural instinct when in trouble is to lift or brake.
Originally Posted by Nyc2kMax
sorry to hear that man... just before the summer tooo
This is how I totalled my 1991 Maxima With an RSB and FSTB. That was a scary day. Sounds like my damage was a little worse though, I hit the wall head on and hit it 3 times while spinning. Glad to hear you are OK though! Thats the most important thing.
litch
123
01-04-2024 07:01 PM
04-16-2020 05:15 AM
magiconthetire
10-26-2015 09:03 PM
