governer
Here's one for $140:
http://forums.maxima.org/showthread.php?t=304346
Thanks for the tips, I know I must sound dumb here but what is a cel? Is there any harm done if a use Apexi RSM and proper tires of course. I learned that lesson when my 89 maxima and a set of toyo touring tires, running from tornados.
It does both, at least the new one does. Check on Apexis' website.
You might double check on the older model, since I know there is an optional G-sensor, but I doubt that makes a difference on the limiter removal. Could be wrong though, so double check BEFORE you buy.
Ive heard that the 2k-2k1 has a top speed of about 140. What will our cars do w/o the limiter?
Tires are improtant, but is there a problem with downforce at high speeds? I might havew to get one of those 3ft tall aluminum wings on my I30.
I would have hoped for a higher top out speed, my 89SE tops out at about 130-135 with some time. I guess it does, spedo stops 120mph but it goes past that and using same increments of measure past that put's it at 130-135. I know the 2000 gle is alot heavier but I would at least hoped for better. My 2000 cuts off around 120, and gets there alot faster than the 89SE did, which also has 240k miles on it and still doesn't miss a beat.
Originally Posted by feyd71
How do you disable governer in 2000 maxima GLE, not speeding of course but lets Iam trying to get away from a tornado or other natural disaster, life and death stuff you know.
only 17" optioned 5spds have no speed limter installed, dunno bout the 3.5Ls since I quit working at Nissan when the 5th gens just came out. I remember I PDI a few of them before I left for Audi. All other Maximas where limited to 130MPH. I have the SE 17" wheels 5spd program in my GXE ECU and I can redline my car with enough road in 5th- rev limiter kicks in at exacly 160MPH. I have every possible bolt on but cams on my 5spd GXE.
QUINCY STEWART
06-15-2002 10:20 AM
