maf difficulties
Old Apr 23, 2004 | 04:31 PM
SmokinOdum's Avatar
maf difficulties
I installed a PR cai and after a week I blew out the MAF. I replaced it with a new one and the car runs fine again but a new SES light (code 0113 ) wont go away. I believe its saying Intake Air Temp Sensor voltage too high.
Old Apr 23, 2004 | 05:30 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
did you replace it with a 2k2 maf? i know some have used 2k-2k1 mafs for their 2k2 but the 2k2 maf has the air temp sensor built into it unlike the 2k-2k1. the 2k-2k1 uses a seperate stand alone sensor for the air temp. if you are using a 2k2, then i would ask if you picked it up from a junkyard or used in anyway? also how long ago did you replace the maf because it will take the ecu a few cycles to realize the code is or should not be there. if you have a known good maf then i would take it to autzone, have them clear the code and see if it reappears.
Old Apr 23, 2004 | 07:00 PM
unrealii's Avatar
You can disconnect the battery to clear the codes.
Old Apr 24, 2004 | 08:08 AM
SmokinOdum's Avatar
I have a 2k2 maxima and i replace the maf with a 2k2 maf. no u cant clear the code by disconnecting the battery... I arleady cleared the code with my obd2 scan tool and the code keeps coming back.
anyone else want to take a stab at it?
Old Apr 24, 2004 | 08:28 AM
sloppymax's Avatar
do you have anyone that you could switch mafs with? if you plug yours into another 2k2-k3 and the same code comes out then you know its a defective maf. it has to be something with the maf since the air temp sensor is built into it.
Old Apr 24, 2004 | 09:25 AM
SmokinOdum's Avatar
Unfortuantly I don't. I may just buy another MAF as a backup and try it to see if its my current maf. If it is, I can just return it under the 1 yr warrantee. But if both mafs get the code, im still stuck for what to do.
Old Apr 24, 2004 | 10:00 AM
03BlkSETE's Avatar
Did you get the TSB done where they replace the old MAF with the newer and stronger one? I'm searching for the details now and will post them when I find them.
Old Apr 24, 2004 | 10:06 AM
03BlkSETE's Avatar
Here's one thread with the new MAF part number.
http://forums.maxima.org/showthread....8&page=2&pp=30
Old Apr 24, 2004 | 10:57 AM
SmokinOdum's Avatar
When I was at the dealer, the only MAF they had on the computer for my car was 22680-2Y001. Which is different from the one listed on that thread.
Old Apr 24, 2004 | 12:05 PM
sascuderi's Avatar
Thats odd because that is the number of the MAF I just installed on my 2000. Does the 2002 have the temp sensor in the MAF or seperate like the 00-01?
Old Apr 24, 2004 | 12:25 PM
sloppymax's Avatar
thats part number for the updated maf for 2k-2k1. the reason that the ecu is throwing the code is because it cannot find the air temp sensor. i would go online like on jerry rome parts site and find the correct part number for your maf. i know the air temp sensor is built into the 2k2-k3 so there is no way that part number will work w/o throwing a code or you can rig the sensor like some other 2k2s have done by relocating the pin for the air temp sensor from your old maf to the 2k-2k1 you have now.
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
ballerchris510
Sep 10, 2015 09:35 PM
jcvgn
Sep 10, 2015 08:03 PM
dcardello
Sep 3, 2015 11:44 PM
