What the is happening>>>>??????
Old Apr 23, 2004 | 08:50 PM
Tim01MaxSE's Avatar
Has this happened to any one....ok when i start from a dead stop and take off at a pretty good rate then shift into second (5spd) the temp gauge drops all the way down then comes back up then happens again when i shift to third...what is going on?????
Old Apr 23, 2004 | 10:01 PM
BigDogJonx's Avatar
The temp gauge moves? Serious issues there. Wonder if either the thermostat is bad or the gauge is bad.
Old Apr 23, 2004 | 10:56 PM
carabuser's Avatar
you sure you're not talking about your tach?
Old Apr 24, 2004 | 01:32 AM
aussie983's Avatar
lol..... to confuse the temp gauge with the tach. hahahaha i doubt it.
Old Apr 24, 2004 | 04:35 AM
† ErV †
it almost sounds like the power to the gauge is cut when you shift. funny thing is, it has nothing to with the shift **** or even transmission.
dixit, if it were an actual cooling issue i am sure you would feel it.
Old Apr 24, 2004 | 05:47 AM
Mick Max's Avatar
Wild at Hurt
Slightly low coolant? It could slosh away from the sensor causing no reading during accel.
Sometimes the plastic over flow jug wont do it
pull the high pressure cap (cold engine only) and try to put more coolant in.
Part of the deal is you HAVE to post back when it is fixed and tell us what the problem was.
Old Apr 24, 2004 | 07:58 AM
Tim01MaxSE's Avatar
Ok guys thanks ill go try it...it also happens when i brake hard too....might be somthing with the fluid ill check it out..
Old Apr 24, 2004 | 07:59 AM
Bucket's Avatar
I think MickMax is on the right track. Check the fluid level in the radiator and top off as necessery. My dad's Yukon had a similar problem. It was a combo of lowish coolant and stuck thermostat.
Good luck
Old Apr 24, 2004 | 10:00 AM
Tim01MaxSE's Avatar
ok this is what i found out....all the fluids are full...so i drove it around a bit and noticed that it goes down when ever there is torque to the motor...so i stopped by my uncles garage and he was thinking that the wire going to the sensor was loose due to the motor rocking back and forth while shifting....and that makes sence to me...now alls i have to do is find the sensor....any one know where it is in out cars...thanks tim
Old Apr 24, 2004 | 12:13 PM
Mick Max's Avatar
Wild at Hurt
That is my other choice. If you follow the upper rad hose down to the v of the engine it should be right there just past the elbow
It makes sense because the engine is moving probably 3/4 inch under torque
and even further under brake torque.
JacksMax
Mar 2, 2001 02:31 PM
