Car fell off jack! Please help!
Old Apr 24, 2004 | 01:21 PM
steelymatt's Avatar
I wanted to take one of my wheels off for the first time. As I was jacking up the car, the soft pavement gave way and the car fell back. It made sort of a popping sound. I'm worried it may have damaged something. I took it for a drive and the auto tranny seems fine, it shifts into park fine. Do you think everything's ok?
Old Apr 24, 2004 | 01:30 PM
kratz74's Avatar
So the wheel was off when the car fell? Or it just fell off the jack? If it just fell - only real possibiity of damage is from the jack itself (maybe gouge the undercarriage). If the rotor hit the pavement b/c the wheel was off, I'd check the rotor and suspension on that wheel. Otherwise, you should be ok. That's why I always use stands. Well worth the $20 for a pair. If you dont have those I use a cinder block or something underneath so I don't get crushed
Old Apr 24, 2004 | 01:34 PM
steelymatt's Avatar
I was lucky the wheel was still on so the rotors weren't damaged. I'm more concerned about what holds the car in park.
Old Apr 24, 2004 | 01:44 PM
† ErV †
nothing got damaged. just don't make it a habit.
and obviously pull up the ebrake up TIGHT, put the car in neutral, PUSH IT so it settles on the ebrake completely, put into park, jack up, put jack stands and have fun.
on and please don't do this on gravel.
Old Apr 24, 2004 | 01:49 PM
2k3TitaniumSe's Avatar
I think your Max will be alright. Remember to use the ebrake next time.
Old Apr 24, 2004 | 02:05 PM
steelymatt's Avatar
So the car needs to be in neutral with the e-brake and not park?
Old Apr 24, 2004 | 03:08 PM
foodmanry's Avatar
Da Roller Coaster!
Put it in park. I don't know what Evil is talking about, he could be referring to a manual transmission.
Old Apr 24, 2004 | 03:11 PM
Maxxxed's Avatar
tEh Hope
maan, that's scary... what if you were under the car?
Old Apr 24, 2004 | 03:16 PM
D Love's Avatar
Evil did say put it into park.
Old Apr 24, 2004 | 03:24 PM
spirilis's Avatar
Never jack a car up without using at least 1 jackstand, and preferably using wheel chocks on the wheels you're not lifting. The cost of wheel chocks (I use yellow plastic ones from Walmart) and jackstands (also from Walmart) is minimal against the amount of damage, quantifyable or not, of being injured or having the car damaged in such an incident.
Old Apr 24, 2004 | 03:29 PM
aussie983's Avatar
oh and btw READ THE INSTRUCTIONS ON YOUR JACK!
It will tell u SPECIFICALLY to put it on a LEVEL STURDY SURFACE and also to use jack stands. NEVER HOLD UP A CAR ONLY ON A JACK!
Old Apr 24, 2004 | 03:39 PM
steelymatt's Avatar
If I'm jacking up the front driver's side, where do I put the jack stands?
Old Apr 24, 2004 | 03:43 PM
Freaknificent's Avatar
i assume push it backwards?
Old Apr 24, 2004 | 05:56 PM
irish44j's Avatar
retired moderator
btw don't use the car's jack...get a nice big hydraulic jack....makes like much easier.
Old Apr 24, 2004 | 05:58 PM
Trance Artur's Avatar
Why were you taking the wheel off??
Old Apr 24, 2004 | 06:09 PM
limsandy's Avatar
Check the manual for jacking points.
~limsandy
Old Apr 24, 2004 | 09:54 PM
FanaticMadMax's Avatar
My jack fell off when I was changing the flat. The jack itself broke, I was so mad since the front rotor was on the ground. I was freaking out, that I thought i might have broke my rotor or my caliper. I had to call my sister to get me a floor jack, the car was a b!tch to jack it up cuz it darn heavy. It was okay after I took it to Nissan to check out my rotor. However, i couldn't get a new jack, Nissan don't warranty jack, and they wanted 80 bucks!!!. Hell, I bought a floor jack, drawback to it, it's not portable to keep in the trunk.
Old Apr 24, 2004 | 09:56 PM
BTW, does anyone know the parts number for the Nissan Jack, since I threw my broken one a long time ago, I need to get one since I don't want to keep a floor jack in my car. Only for at home use.
Old Apr 24, 2004 | 11:42 PM
limsandy's Avatar
OEM jack is
~limsandy
Old Apr 25, 2004 | 03:27 AM
MrGone's Avatar
I was at a friends house when he was moving the car around (no engine in the car, front suspension apart). Somehow the car slid off the jack. Luckily the only damage was the license plate frame. We were worried about the strut mounts and rotors but they escaped unharmed. Only time I've seen a car laying on rails lol.
Personally I have a 3.5ton jack that I've used on everything, I got it at Costco a year ago . Also technically when your jacking up the car it should be in neutral and no parking brake and chalk the wheels.
Old Apr 25, 2004 | 05:05 AM
Zero Deuce SE's Avatar
What kind of pavement are you referring to? If it was dirt or gravel, it's never a good idea to use a jack on it without some kind of float pad underneath the jack. I would recommend you use a 1 foot square piece of plate steel to place the jack on before raising your car if you don't have a concrete surface to park your car on. The palte will distribute the weight over a larger surface area.
Old Apr 25, 2004 | 05:37 AM
Virus's Avatar
Buy ramps!
Old Apr 25, 2004 | 05:58 AM
Originally Posted by Virus
Buy ramps!
They will only help when working underneath the car. He wanted to remove a wheel. You still need a good and stable surface to use ramp on.
Old Apr 25, 2004 | 06:09 AM
AKM2k5's Avatar
yeah, evil said put it in neutral, pull the e-brake, then put it back into park..... But what do you manual guys do? Does the front brakes lock also with the ebrake?
Old Apr 25, 2004 | 11:53 AM
UncleMax98's Avatar
New one from dealer would cost $$$. Maybe you can buy a replacement jack from the junk yard?
Old Apr 25, 2004 | 12:12 PM
asu174's Avatar
Clay Aiken has fancy genitals
Put it in gear.
Old Apr 25, 2004 | 12:25 PM
Supreme Allah's Avatar
i got a hydraulic jack and 2 stands for like 20 bux at Pep Boys ~
it was on sale from 30 bux which is still a damn good price and worth it even if you only use them once. although you will end up using them a lot.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
JMag90
Aug 25, 2015 09:17 AM
N2deep
Aug 16, 2015 08:30 PM
Balkins
Aug 12, 2015 06:39 AM
