SES Light is On
Old Apr 26, 2004 | 06:08 PM
ttboy's Avatar
SES Light is On
I had the SES light come on in January, took it to the stealer and they proceeded to rape me. Diagnostic charge - $85 bucks. Then the code comes up as the rear O2 sensor. Here comes another rapeage. So they replace the rear O2 sensor. Not even 4 months later, the SES light is back on? I don't want to go back to the stealer (my *** is still sore from the last time), is there any other way i can find out for myself what the problem could be? I've read posts that AutoZone will do a diagnosis for free but I'm in Toronto Canada so we don't have an AutoZone here.
thanks
Old Apr 26, 2004 | 06:28 PM
GLE2000's Avatar
Find a local parts store that is a major chain. They might scan it for you for free.
Old Apr 26, 2004 | 06:55 PM
irish44j's Avatar
retired moderator
You can buy the SAME scanner that the dealer and Autozone uses for about $150. Then you will never have to pay for diagnostics again.
Only place I know of to buy them is, um, Autozone and Advance Auto...but I'm sure you can get it online too..
Can't remember what it's called exactly - someone else here holla!
Old Apr 27, 2004 | 01:00 AM
BrownMango's Avatar
My ses light for my 2K max is on too, I don't want to get raped either, and I live in Toronto. I read the code my self by grounding the number 9 pin on the ECU data interface. Turn the ignition on (DO NOT START THE CAR) and count the number of times that the indicator lights flashes you can get the code. Let me know if you want more details on this, I'll post...
Old Apr 27, 2004 | 03:34 AM
Chinkzilla's Avatar
details please!
Old Apr 27, 2004 | 03:41 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
thanks
if you have a 2k-2k1 then there is a tsb concerning the oxygen sensors. they will charge you for the repair if you were out of the 3yr/36k warranty unless you had some form of extended warranty. if you are cali spec, the tsb calls for replacing 2 o2 sensors (even if the light is only on for one) and also flashing the ecu. i am not sure what tolerances are changed with the flash but i have not had an issue after having the tsb covered under extended warranty.
Old Apr 27, 2004 | 08:47 AM
unrealii's Avatar
I think the tsb even covers 2k2's. I always thought the dealer had to warranty their repairs for a 12 months, 12k, so if the light is on for the same reason as before, dont they have to fix it?
Old Apr 27, 2004 | 01:08 PM
ttboy's Avatar
Details would be great. Thanks.
Old Apr 27, 2004 | 04:01 PM
CT MAXOUT's Avatar
I'd appreciate the details on pulling the codes manually. Used to do it on my older cars with a paper clip. Didn't realize its possible with these cars. I just bought my 02 a freakin month ago and its already throwing codes.
Does someone have a link to a list of trouble codes? None of this info was in the FAQs and well, you all know about the search function.
Old Apr 29, 2004 | 01:57 AM
BrownMango's Avatar
I got some pics taken of what I did, I'm just waiting for the usb cable for the camera to download them. (Should get it from my dad this weekend)
I'm using the alldatadiy.com site for the trouble code (paysite).
Old Apr 29, 2004 | 04:09 AM
CT MAXOUT's Avatar
Last night I pulled code P1456...Aux. Emissions Control...last night with a scanner. I was thinking that the light coming on somewhat coincided with filling up the fuel tank the other day. I checked the cap and it wasn't loose, but the light ended up going off yesterday anyway. Is that code for the gas cap hopefully?
Old May 2, 2004 | 09:12 AM
ttboy's Avatar
Can someone please post the procedure on how to manually pull the codes?
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
