SE-R shifter vs Maxima's
Old Apr 28, 2004 | 09:51 AM
Vadim's Avatar
Does anyone know if the shifter from 6-speed Sentra SE-R is the same as 6-speed Maximas?
Old Apr 28, 2004 | 11:53 AM
hct67's Avatar
I Wish
I Wish is was the same because if it was I would buy it and replace the way to long of a shifter my 03 Maxima has. The only thing I am hoping since no one is making one for the 03 Maxima is that the New Altima SE-R will have a short shifter this fall and I can get one of those!!!
Old Apr 28, 2004 | 12:28 PM
Vadim's Avatar
B&M makes a nice one for SE-R I am planning on pulling my shifter out, studying it and I will try to get one manufactured with a shorter throw. Depending on costs, might be able to get a few produced if people are interested.
Old Apr 28, 2004 | 01:20 PM
jeepik's Avatar
YES sts is what we need for the 6 speed..its begging for it
Old Apr 29, 2004 | 11:32 AM
MaximaSe2002's Avatar
you don't want the specv shifter its terrible i had one before the max they are really notchy and most of them grind
Old Apr 29, 2004 | 02:07 PM
wojowojo16's Avatar
I had one too and I agree with the comment above.
Old Apr 29, 2004 | 03:47 PM
Jaws's Avatar
My brother in law has an '03 SpecV which shifts much nicer than my Max. I find no notchiness with it whatsoever, and it is almost Honda smooth.
Old Apr 30, 2004 | 10:20 AM
they might have fixed it then in 2003 because i think i had a friday car because of all the problems i had with it
Old Apr 30, 2004 | 11:12 AM
Maximass's Avatar
what about the one from the G35??? wouldnt that fit?
Old Apr 30, 2004 | 12:13 PM
Vadim's Avatar
G35 is a RWD car. I believe the shifter sits right on the tranny.
Old May 1, 2004 | 10:53 AM
Speed6's Avatar
I agree, the Maxima shifter is awful. It needs to be cut down about 2 inches. It should be essentially a metal rod that then connects to the linkage. You could cut a section out of the rod and re-weld it lower. Its not quite the same as the nice aftermarket short shifters, but it will reduce the throw.
I need to get around to doing this instead of just talking about it
Old May 1, 2004 | 07:35 PM
MaxedOut's Avatar
my little brother has a 02 spec v which i am currently drivign because i need new tires for my max.. the throw IS shorter.. but it is also notchy, especially 1st-2nd shift...
i don't mind my maxima shifter... it might be alittle long but it is decent...
after driving my brothers car for almost a month.. i kinda miss my shifter...
Old May 2, 2004 | 04:22 AM
yeah i finaly drove a 6 speed max the other day and the shifting is a lot smoother than the specv
Old May 2, 2004 | 08:09 AM
BP2K2Max's Avatar
my friend has a spec-V. there is no collar to prevent your from hitting reverse when you try to go into 6th gear as in the 5.5 gens. the first time i drove it i just put the shifter all the way to the right and grinded(ground?) reverse when trying to engage 6th gear. i suppose it takes getting used to.
Old May 2, 2004 | 01:58 PM
ga2000's Avatar
i have a 02 spec v the shifter sucks. very noisy and notchy. third gear grinds going in ever since 1000 miles on the car when u red line it.. other than that no grind... 6th is easy it takes sometime getting used to but its smooth. and there is a thump so u know u are in the reverse gate. its not a lock out but u do know u are going into reverse its ALL THE WAY over and down.
maxima-junky
Oct 21, 2015 05:17 PM
maxima-junky
Aug 13, 2015 09:59 AM
Trin1j23
Aug 12, 2015 08:31 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
