Help - Sunroof only opens/closes a couple of inches at a time??
Old Apr 28, 2004 | 12:56 PM
PhillyFanCS's Avatar
I have searched but found nothing re: this problem. Anyone experience the sunroof only opening or closing only 2-3 inches at a time. Do I need a new motor or is there a known fix. Any help would be greatly appreciated.
Old Apr 28, 2004 | 12:59 PM
Vadim's Avatar
have you recently unplugged the battery? there is a reset procedure for a sunroof, I believe you have to hold either tilt up or down button for a couple of seconds. It is also in a car manual
Old Apr 28, 2004 | 01:33 PM
I have not recently unplugged the battery but I only bought it a couple of months ago, 2000 SE. That's great, sounds like there is a fix/"Reset Procedure". Does anyone have more detailed info/instructions on this procedure?? I do not have a Service Manual.
Old Apr 28, 2004 | 01:39 PM
Nyc2kMax's Avatar
yeh what u got to do is unplugged the battery. I happen to me when i first brought the car
Old Apr 28, 2004 | 01:52 PM
That's it?? Just disconnect and reconnect battery?? Does it need to be disconnected for a certain amount of time??
Old Apr 28, 2004 | 02:12 PM
KL99SEA's Avatar
for my 03 the procedure is in the ownwers manual.....look there first.
Old Apr 28, 2004 | 03:50 PM
2002 Maxima SE's Avatar
I tried two things:
1)Hold the close tilt button down for 20 seconds. This resets the sunroof (you'll here a click).
2)Unplug the relay under the steering wheel.
Neither one helped my problem with the sunroof. Finally I took it to the dealer and they updated the software. Sunroof works flawlessly now.
Old Apr 28, 2004 | 05:24 PM
maximillus's Avatar
it could be your fuse
Old Apr 29, 2004 | 06:06 AM
If it was the fuse wouldn't it not work at all?? When I close and or open it moves a couple of inches and then there is a click at the switch.???
None of the above mentioned suggestions worked but thanks for the input.
Old Apr 29, 2004 | 06:23 AM
Nyc2kMax's Avatar
cool
once the problem is fixed.... I hope you didnt not have to pay the stealer for the work.
Old Apr 29, 2004 | 06:35 AM
Colonel's Avatar
Old Fuddy Duddy
Guys, he has a 00. Its a MECHANICAL sunroof so all the reset suggestions dont apply here...that process only applies to 02+'s.
I do remember hearing of issues like yours and a motor/pc board assembly needed to be replaced, but I am not 100% if that will be your solution.
Old Apr 29, 2004 | 06:55 AM
Sounds like I was trying fixes which don't apply to my year, anyway..... I will see what the dealer has to say but I think pushing the switch 5 times to open or close is a pretty cheap alternative. Also the sunroof is a little unlevel and I have heard there are shims which can be put in to level.?? Any info on that??
homeyclaus
Sep 3, 2015 06:15 PM
BobMax
Aug 21, 2015 07:38 AM
BobMax
Aug 15, 2015 12:35 PM
altome15
Aug 10, 2015 07:05 PM
yat70458
Aug 3, 2015 01:16 PM
