Requesting AE Engine cover pic and answer
Old May 7, 2004 | 06:46 AM
GaMax97GLE's Avatar
I just bought an 2001 AE Engine cover. I held it up to where it should mount and only the top two bolt holes line up. Did they send me the wrong cover or is it supposed to be that way? I don't have an AE Maxima so could this be the problem?
Thanks y'all.
Old May 7, 2004 | 07:08 AM
MichaelAE's Avatar
Not sure how to answer your question, but below are two pictures of my engine bay with the cover. Larger versions can be found on my web site.
Cheers! Good luck finding the right hole for your screw.
dr3ams661's Avatar
Thanks y'all.
Make sure you get the mounting kit for the AE cover. If you don't have it, you can contact DaveB. Without the mounting kit, you can't install it because the lower two bolts that are in the middle of the engine cover are attached using the mounting kit. I hope this helps.
Old May 7, 2004 | 07:53 AM
JdoubleOe703's Avatar
teddibear703
in the pic, what is the black thing right above the AE cover called? I always wondered.. its the black thing with the 6 pipes in pairs.... lol, i should know this but i dont..
Old May 7, 2004 | 07:55 AM
teddibear703
hey michaelae, what brand hoses are you using? what are the sizes for those hoses? thanks!
Old May 7, 2004 | 08:23 AM
MichaelAE's Avatar
I ordered the Starter Kit from HoseTechniques.com and that took care of it for me with a few exceptions. The largest hose for the intake had to be purchased from a local shop...I think it was 12mm. Some of the 3.5mm, 4.0mm, 6.0mm, and 8.0mm hoses are direct replacements...but I had to split and cover a lot of them.
Old May 7, 2004 | 08:55 AM
teddibear703
what are those lighter blue hoses? it doesnt look like silicon hose. Do they carry direct replacements for those hoses?
Old May 7, 2004 | 08:59 AM
MIKE2K2's Avatar
Custom User Title
the intake manifold.
Old May 7, 2004 | 10:01 AM
GaMax97GLE's Avatar
Thanks MichaelAE and dr3ams661...that's exactly what I needed to know. I do have the correct cover, just need the install kit.
Old May 7, 2004 | 10:08 AM
MichaelAE's Avatar
That is split wire loom wrapped around the non-replaceable hoses and wire clusters and taped with blue electrical tape. Looks great even in person.
Old May 7, 2004 | 11:10 AM
dr3ams661's Avatar
no problem. Once you get the mounting kit, the bottom of the mounting kit will screw onto two holes on your valve cover. The AE cover will then screw on to the top of the mounting bracket.
Old May 7, 2004 | 12:04 PM
redstradic's Avatar
Matt93SE
Apr 8, 2018 09:23 AM
conansriver
Sep 3, 2015 06:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
BassAddictJ
Aug 4, 2015 11:38 AM
