FYI: If you need a Switch installed & want it to look OEM...then they have switches @
FYI: If you need a Switch installed & want it to look OEM...then they have switches @ Pepboys that are perfect fit.
Professional Conduct ~ Tite!(is the brand name on package) makes switches that fit directly into slot w/o modification. Box has name as OE STYLE ON/OFF ROCKER 20 AMP
-The black ones that dont light up are part#86910 or upc#37495-6910
-The Red ones that light up red when in ON position(see *pic*) are part#86900 or upc#37495-86900
*pic*
p.s. They also have switches that light up blue & green.
*pic*
Originally Posted by krazyd
Could you take a better shot when get a chance?
Does the switch come with a plastic housing? How is it a direct fit?
I don't see either of those part numbers on PepBoy's website.
~ Kirk
~ Kirk
Yes switch is in plastic housing that you just fit in directly into slot opening.
Well I got my from local pep boys not website....also I went to local autozone, they had this brand but didnt have this exact part# either/switch....so not all places have it.
Originally Posted by wildmanal
Wow thanks. Is this is the switch you used with your DDEs? I'll be sure to check it out when that time comes.
i have a red switch connected to my underbody street glow kit & soon will have the black switches to work with aftermarket heaters & massagers in seats
Originally Posted by Pir8 97
Are all the housings black? That might look kinda
with a Frost interior.
p.s. black goes with any color
Originally Posted by KiLLeR2002se
Well, half of the frost switches are already black. You can always make your own and drill a whole in the plastics to make it look OEM.
I just think it's good to know for future installs that such a direct-fitting part is available.
~ Kirk
