Pro-flow aftermarket MAF sensor
Old May 10, 2004 | 04:03 PM
MAXINXS's Avatar
Check out these guys
http://pro-flow.com/Gallery%20Files/75mm%20plastic.htm
I'm not 100% sure these would work, but I think they will. I've sent them an email to find out for sure. $210 is one hell of a lot better than $400+ for OEM.
Not only are they cheaper, look here
http://pro-flow.com/Import/import%20front.htm
12 hp gain with a new MAF for $210. Doesn't sound like a bad deal at all. They are also programable.
Old May 10, 2004 | 04:05 PM
SoonerFan's Avatar
Cletus
are those for our car? im pretty sure they are car specific. it has to work with the ecu.
Old May 10, 2004 | 04:35 PM
UMD_MaxSE's Avatar
Got Bent?
you need to find out what the output voltage range and output response of the MAF is and see if our ECU can accept that range of voltages...
Old May 10, 2004 | 05:01 PM
Wurf's Avatar
Pro Flow, makers of Pro M meters
Guys,
This outfit is top notch. Amost any car that uses a MAF - these guys can make a meter for it. They custom calibrate every meter for your car according to your injector size and your ECU requirements.
They also make a meter called a Univer, which does not have a sample tube in it for the MAF sensor. Instead, it has a series of sampling holes drilled around the periphery of the inside of the meter. It flows very well, but it's expensive.
Check the import section
Old May 10, 2004 | 05:40 PM
BEJAY1's Avatar
Conecarver
We'll they do offer a 30-day return policy. Who's near Detroit and has a spare MAF to loan em?
Old May 10, 2004 | 11:13 PM
cobymoby's Avatar
From what I read on their page, it is converting AFM's (air flow meter) to hot wire MAF's which we already have. An AFM is what is also called vein meters. How they work is that their is a flap that physically moves as the air passes though it. More air will move the flapper or vein more (like a weather vein).
We already have what they sell.
HKS had a product like this years back, the VPC or Vein pressure converter. It works the same way, but it converted AFM to MAP and IAT like a Honda motor. Most of the stand alone engine management computers will use MAP and IAT to measure air.
chisam14
Nov 6, 2018 08:56 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
hayne
Oct 5, 2015 11:53 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
ac max 92
Sep 17, 2015 07:35 AM
