Help... Door Creaking!!! Sounds Terrible
Old May 10, 2004 | 06:37 PM
nhokt's Avatar
Hello,
Recently my drivers side door has started to creak and pop loudly when I open and close it; it sounds terrible and is actually embarassing! What exactly do I need to lube or replace to fix this?
Old May 10, 2004 | 07:32 PM
MaxZ71's Avatar
try some WD-40 on the hinges. That should fix the problem
Old May 10, 2004 | 07:36 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Grease is the word.
Old May 11, 2004 | 02:49 AM
nhokt's Avatar
Originally Posted by SEmy2K2go
Grease is the word.
I took my tub of moly chassis/hub grease and hit all the moving parts and the noise improved but didn't go away... it's really unbelieveable to me... ahh nissan.
Old May 11, 2004 | 03:19 AM
Zero Deuce SE's Avatar
3 words for you. White lithium grease.
Old May 11, 2004 | 05:40 AM
scopium
that just shows that you havent brought it to your dealer for service.. because they grease all the hinges and stuff when that happens
Old May 11, 2004 | 08:31 AM
SilverSleeper's Avatar
Mine recently started making a rubbing sound. I've narrowed it down to the front corner of the door that overlaps at the windshield/hood area. The corner actually rubs the rubber and makes a noise. Not sure what I need to do there.
Old May 11, 2004 | 08:37 AM
MaximaPolak's Avatar
Well just so you know....I have the same problem and i know what is causing it......Where the Rubber Seal Along the door meets the corner of the front part of the door (as you get out: toward the front...) there is a peace of the door that seems pointed and that causes the rubber to rub on the door.....I use Armor All each time i wash the car on that little spot and the door stops creaking.
and it's now quiet (if that was your problem)
Old May 11, 2004 | 08:26 PM
nhokt's Avatar
Thanks I will give that a try tomorrow! I think my problem might be a little moree than that though, I get a mechanical cluncking/poping noise, anyone get this at all?
And to scopium regarding the dealer... YEAH RIGHT! My car has been at the dealer twice in the last month; once for tranny solenoids and another for a TCM...
Old May 12, 2004 | 06:37 AM
Cdoc's Avatar
I had a "popping" noise coming from my passenger side door whenever I opened it. I put up with the noise for a while but then when I looked at it there was just a loose bolt. Hope this helps.
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
MaxiNoob98
Oct 2, 2015 10:13 PM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
