Who Installed their own Suspension?
AAAAARRGG!!!
Is it just my car, or does Nissan REEEALY tighten down the bolts connecting the struts to the hub?
Ive been spending the last HOUR trying to remove these bolts (front, havent even tried the rear yet). In the process I have broken TWO wrenches including a close to 2ft torque wrench! I have bathed them in WD-40 and banged on them with a hammer.
I am just about out of ideas. I was thinking of getting some pipe and making a breaker bar, but I dont want to bust another wrench. I dont have a torch. Im desperate, maybe Ill use a lighter
i did my own, although i installed the rears first, then the fronts. i hear your case, it's nothing an impact wrench can't solve. i hope your hardware has a lifetime guarantee, get that sheeit replaced. good luck, bro.
Thanks for the replys guys.
Okay. So I went out and bought a breaker bar and a 1/2"-3/8" addaptor... Got home, gave it some muscle and... TWISTED AND BROKE OFF THE F*UCKING ADDAPTOR!!!
After this I decided to call in a favor at my Infiniti dealer. They were cool about it and told me that they would take care of it. Maybe 10 min. later they say that their tech. wont touch it. WTF. They said that maybe an independant shop would do it.
Took the car to TWO shops and neither of them would do it either!
Finally I used my brain
and bought an impact socket for my 1/2" breaker. It worked like a charm and solved my problem
Well sort of... Turns out that the rear struts are on there pretty good too, and of course require a different size socket. So rather than try to break another of my 3/8" sockets, I will just go out tomorrow and buy the correct size impact socket.
So for now i have the front done and am pretty happy about that. I have been waiting soo long to install these. Wish me luck with the rears tomorrow. It looks like I have to remove a cross-member in the trunk to get to the rear strut towers.
And for all that suggested that I just pay to have them installed for me. I will go a LONG way to keep other people from touching my car! Plus I think its fun to be able to do it yourself.
and bought an impact socket for my 1/2" breaker. It worked like a charm and solved my problem So for now i have the front done and am pretty happy about that. I have been waiting soo long to install these. Wish me luck with the rears tomorrow. It looks like I have to remove a cross-member in the trunk to get to the rear strut towers.
Originally Posted by Max's Max
Do yourself a favor.....run out and get an impact gun. An electric one will do. I did all four sides in under 3 hours. The right tool is everything.
With all the tools mentioned, the single most helpful tool used when my buddy and I did my install was penetrating spray. You can pick it up at Lowes, HD or any parts store. Let the penetrating spray sit for 5 minutes or so and then use a 1/2" breaker bar. We didn't even need the impact wrench on the fronts, but the rears are what gave us some issues. Stood on the breaker bar to work the back set loose. Other than that it was a breeze.
the bolts are 17mm and 19mm if i remember correctly.. anyway I had a b!tch of a time with it too, but only with one bolt.. no matter what i tried it would not come off, it got stripped to hell.. Finally i got fed up and went out and bought air tools. STILL wouldn't come off.. i just drove over to just tires and paid one of the workers 10 bucks to put it on a lift and impact it loose. Then I drove home with it slightly loosened, my own impact wrench got it out the rest of the way.
Why the **** would you use a torque wrench to remove bolts........?
But yeah I feel your pain on the rear struts. Took me about two hours and finally had a friend come over that had this badass like $150 ratchet with a breaker bar and stomped on the thing. It made some horrible racket and I thought he broke his wrench, but it came off. Definitly the hardest part charging the suspension.
i had the same problem. me & some buddys of mine broke a craftsman ratchet & one durabuilt ratchet. the gear in the craftsman was stripped & the lil square head on the durabuilt snapped right off! after a few hours of playin with my nuts (no pun intended), i used a wrench (on the side with the nut) & banged the **** out of the wrench with a 15lbs dumbell. 10 sec later... poof my nuts were free!!! who says you need air tools?? my "planet of the apes" method works just as well!!!!
It took me under 20 minutes to replace the front left shock on my moms 99SE...
Those bolts tend to stick and require 1000LBS of torque to get them off lol..
Actually , my electric impact gun is a MIRACLE worker!! I picked mine up for $80CDN... its better than driving out and getting a mechanic to remove the damn bolts!
For those of you still reading this thread:
I finished everything up today and all I can say is... WOW!
I have the Illuminas set to "5" (the stiffest setting), and my car handles like its on rails. The ride is a little harsh, but i dont think it is anywhere near uncomfortable.
I do have a couple concerns though:
When I was doing the rears (yeah yeah, laugh it up), I didnt even have to compress the coils to put them on the struts.??? i was not comfortable with this so I chopped down a little rubber bumper about 1/2" to make a tighter fit. This made it a little tighter, but I am still a little worried. Did anyone else run into this, or am I doing something wrong? I would think that anyone running the Teins would know for sure.
Also, the rear struts (right around the top strut mounts) are making a slight creaking noise when compressed/decompressed. hey, maybe it has something to do with the aforementioned problem. Do you think the springs just need some time to settle?
Any help on these questions would be much appreciated.
I have the Illuminas set to "5" (the stiffest setting), and my car handles like its on rails. The ride is a little harsh, but i dont think it is anywhere near uncomfortable. I do have a couple concerns though:
C'mon, I know you guys have ideas about whats going on.
I especially want to hear back from the guys with Teins. Since the springs are so short, I would like to know what you ran into with the rear struts.
My questions are above.^^
TIA
TIA
Im not too worried about that, I was just wondering if anyone else ran into that. I dont think there are many times when the rear suspension is completely unloaded.
Do you get any noise from the rear? If I get into the trunk and bounce up and down I can hear a creaking noise comming from the rear strut towers. Everything is tight so I dont think its that.
The reat strut mounts are not directional like the fronts are they? If nobode knows I may just wait a few weeks and see if it was just the springs setteling. Although I have never heard this before (with lowering springs).
Originally Posted by Ammi
Didn't know fronts were directional. I just made sure the word "out" on top hat was pointing towards me.
mine were on pretty tight, but it was nothing the old pythons couldnt handle...lol..just soak them in a penetrating lubricant i.e something like pb's grab a craftsman, and push or pull.
MaxLife17
Jun 27, 2019 01:37 PM
Violator
Sep 9, 2015 10:14 AM
