jic coilovers
Old May 16, 2004 | 09:28 AM
5 spd's Avatar
jic coilovers
I purchased a set secondhand, and upon arrival, one of the springs is way loose. the lower spanner ring that holds the spring in place is about a half inch lower than the opposite side, and the spring is not securd. my question is, do I just compress the spring enough to get the rings snug underneath the spring?
I have contacted jic so far, and I am about to contact the seller.
Old May 16, 2004 | 10:31 AM
PhxBlue's Avatar
MK3 Supra and Focus ST
Yes just move the ring up till the spring is snug then tighten it down, down go up too far or you will compress the spring. That is all you need to do. Make sure though that you measure the distance of the the top and bottom rings on both struts to make sure they are equal length.
Old May 16, 2004 | 11:33 AM
5 spd's Avatar
thanks so much. I haven't worked with a co8l sprung suspension before. I assumed that was the proper way to install springs, but I needed clarification. karma to you
Old May 16, 2004 | 03:40 PM
5 spd's Avatar
ok, I must have misunderstood your post. I thought I needed a spring compressor, but upon discussion with a friend that had loaned me some spanner wrenches said that I do not need to compress the springs, which I had assumed.
so all I have to do is bring the upper ring to the coil so that it is touching, and snug up the lower ring to lock the rings together?
Old May 16, 2004 | 03:42 PM
djfrestyl's Avatar
Suspension Yoda
you need to bring the lower ring up so that its touching, but even further so that it is lining up with the other front coilover...they should be the same. then bring the other ring up to tighten it up
Old May 16, 2004 | 03:49 PM
5 spd's Avatar
ok. should it be a good idea to check the other coilovers to see that they are the same or just leave it?
Old May 16, 2004 | 05:29 PM
Bulldawg's Avatar
I did a write up if you want it, email me.
Old May 16, 2004 | 07:36 PM
5 spd's Avatar
email sent
BkGreen97
Apr 2, 2016 05:47 AM
NewMax03
Oct 7, 2015 08:27 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Garrettz459
Sep 28, 2015 02:50 PM
