driver window squeals on the way up. FIX???
Old May 21, 2004 | 05:59 AM
silversurfersg's Avatar
My driver window squeals on the way up. the squeak is kinda loud so its annoying. There might even be a TSB for it. I have a 2001 AE. Anyway i can just pull the door off and throw some lube in there without having a dealership fix it? any ideas would be much appreciated.
Old May 21, 2004 | 06:01 AM
MrGone's Avatar
My Dad's 2000 SE does that aswell, I was going to take a look at it but he's always driving it, lol.
I think some lithium grease on the rails might fix it
Old May 21, 2004 | 06:11 AM
schernov's Avatar
Not lithium grease, but some graphite lube at Autozone for 2.99 a tube.
Old May 21, 2004 | 06:14 AM
MrGone's Avatar
ah thats right.
I actually have some of that too (back from when I was a youngian and made pine wood derby cars in boyscouts )
Old May 21, 2004 | 06:50 AM
OK. graphite lube. But where? has anyone done this
Old May 21, 2004 | 08:19 AM
Old May 21, 2004 | 08:59 AM
Max2000SE's Avatar
I would like to know as well. I have a 2000 and it makes a reallyl ouod annoying noise on the way up...I dont tell Nissan b/c they will try to tell me its from the tint, even though it did it before...Is this lube the answer?
Old May 21, 2004 | 09:08 AM
aussie983's Avatar
i think someone on an earlier thread mentioned applying silcone lubricant. It is a dry lubricant, which should be a applied on the vertical track of the window closest to the middle pillar.
Old May 21, 2004 | 09:41 AM
so obviously you need to pull the door apart i assume. do you think regular silicon will work as well because i know i have that at the house
Old May 21, 2004 | 09:45 AM
WVmax's Avatar
I have a 2000 SE, and my driver door does the same thing. Is there only one place that you're supposed to apply the lubricant?
Old May 21, 2004 | 10:21 AM
UGAd13's Avatar
Nope. All you have to do is: roll the window down and spray the lube inside the vertical part (track) of the open window. Roll the window back up and down a couple of times to work it in and that should do the trick. If you go the parts dept at Nissan and ask them, they'll hook you up. It's only a couple of bucks for a whole can. Not sure what kind of silicon you have at your house, but better to be safe than sorry.
Old May 21, 2004 | 10:24 AM
JC_2k_SE's Avatar
i as well had the same problem on my 2000 max. i took apart the entire door panel and lubed up the inner tracks but the problem is still there
Old May 21, 2004 | 10:35 AM
01SE02SER's Avatar
Faster than a speeding bullet...
Roll the window up all the way. Clean it as best you can on both sides. Get some silicon spray and spray it on the glass, then wipe it down.
You can get the silicon spray can from Nissan (even Toyota sells it for less than $10).
Peace.
Old May 21, 2004 | 12:36 PM
takkar's Avatar
try some talcum powder on the felt that the glass rubs against...i used baby powder
Old May 21, 2004 | 03:47 PM
aussie983's Avatar
its silicon lubricant NOT SILICONE CAULK...thats a totally different story
Old May 21, 2004 | 04:57 PM
Ammi's Avatar
350 Detroit Muscle
I hope nobody was dumb enough to actually use silicon caulk on their window
Old May 21, 2004 | 07:26 PM
Y2K1JKSE's Avatar
phew i'm glad to see that i'm not the only one with this problem...i took it to the dealer cuz both windows were doing that and they actually fixed the driver side but the pass. side still squeals and goes up slower then the rest..guess i'll have to go get some of that lube.
Old May 24, 2004 | 05:16 AM
ill def have to try that out
Old May 24, 2004 | 06:08 AM
GaMax97GLE's Avatar
Silicone Spray
that Nissan sells. Couple bucks for the can. I used it on all windows and everywhere else. Same thing the dealer uses.
Old May 24, 2004 | 09:52 AM
GetSome681's Avatar
I've been having this problem for about a year now...just too lazy to do anything about it. Let me tell you, it sure doesn't impress a girl when you go to roll up your window.
Old May 24, 2004 | 10:34 AM
NewLoveI30's Avatar
Hey, you should keep the can in the car. After you impress that girl with your silent windows, maybe you could use a little on her Squeeek, Squeeek!!! LOL
Old May 24, 2004 | 10:58 AM
Y2K1JKSE's Avatar
hahah its soooooo embarassing when ur at a light or something and u roll up your window and it squeaks sooo loud that everyone else looks at you...people that ride shotgun get scared when it makes that noise haha
Old May 24, 2004 | 11:21 AM
its not bad for getting girls attention if u cant whistle lol
Old May 24, 2004 | 12:13 PM
NewLoveI30's Avatar
Do your windows squeek all the way up? Mine just gives a little squeek from the weather stripping at the top of the window.
Old May 24, 2004 | 08:06 PM
alicious's Avatar
the org...not what it was
I'm also glad it's not just me, I have the same problem on my drivers side door. I'm going to have to try this, but does the Silicone leave a residue on the window after you apply it?
Old May 25, 2004 | 04:43 AM
i agree... does it leave a residue? everytime i put the window down then back up will it be all over the window?? and is the inside of my door going to be filled with this stuff. should i just have the nissan dealer do it?
Old May 25, 2004 | 05:14 AM
PhillyFanCS's Avatar
I used the silicone spray a couple of months ago and it still leaves a horizontal line where the window is stopped when rolling down. I am going to try the graphite next time.
Old May 25, 2004 | 06:38 AM
GaMax97GLE's Avatar
Well it leaves silicone...
But, you spray it in the tracks, where the glass slides. So you never acutally see anything left over.
Old May 25, 2004 | 06:40 AM
GaMax97GLE's Avatar
It just goes in the tracks of the window. You won't have a pool of it at the bottom of your door, if that's what you mean. You will never see the spray on the glass since it just goes in the tracks. This is the easiest thing ever.
Old May 26, 2004 | 03:21 PM
alicious's Avatar
It Worked!!!!
I stopped in @ a local Toyota dealer yesterday, grabbed a can of the silicone spray, cleaned my window, lowered it, sprayed it in the tracks, let it sit for about a minute, rolled it back up and ureaka!!!! That irritating squeaking is gone, not too mention there is no excess silicone (that I can see) on the window!!! Thanks for the help guys!!! :-D
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
