INSIDE a 2000-2001 Variable Intake Manifold(Pics!)
Old May 25, 2004 | 11:36 AM
  #41
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What's a "VAIS"?
Originally Posted by SR20DEN
I know the secrets of the broken VAIS.
Old May 25, 2004 | 11:49 AM
  #42
spirilis's Avatar
Hmm, are the "secrets" anything we don't already know? (if so, I wanna hear! I wanna hear! )
Old May 25, 2004 | 12:00 PM
  #43
SR20DEN's Avatar
VQ Wizard
Yes.
Be patient. All will be explained before the end of the week. Along with a pleasant suprize for you DE-K owners.
Old May 25, 2004 | 12:03 PM
  #44
spirilis's Avatar
Yes.
But daaaaaaaaaaad, I wanna open my presents now!!!!
LOL j/k, I probably won't have the time to touch my car until the end of the week
Old May 25, 2004 | 12:59 PM
  #45
mad2kmax's Avatar
I know something you don't know....
Old May 25, 2004 | 01:49 PM
  #46
mad2kmax's Avatar
Wanna know? Here's the link.... http://forums.maxima.org/showthread....87#post2976387
Old May 25, 2004 | 02:41 PM
  #47
spirilis's Avatar
Originally Posted by mad2kmax
Ohhh, right. Gotcha. I guess the mod here is that the lack of a rod produces less restriction than just having the power valve open all the time.
I think I did that experiment once by hooking up my vacuum pump to the VIAS fresh air port and maintaining a vacuum on it. Kept the vacuum pump tucked between the airbox and the battery. Problem was, the sh*tty tubes that came with the vacuum pump collapsed
Old May 25, 2004 | 03:44 PM
  #48
Progress's Avatar
It's business time.
Is the reason why the stock 5-spd 97-99 versus the stock 5-spd 00-01, where the the former is sometimes the same if not faster than the latter (in 0 to 60 springs), due to a malfunctioning in the VIAS? I know my car doesn't feel nor does it sound any different after 5000 RPM.
Maybe the VIAS aren't even working when they come off the line so when they are magazine tested, they are slower than developed to be. Or maybe, thats a stretch.
Old May 25, 2004 | 03:55 PM
  #49
spirilis's Avatar
Who knows... maybe that's another reason they switched to a metal manifold in (2k1? 2k2?)
Old May 25, 2004 | 09:32 PM
  #50
P. Samson's Avatar
I just inspected mine and took some pics. I see how the vacuum/fresh air is routed now. Still not sure about the vacuum check valve... I pushed a small straw (from a can of STP silicone spray) through it and sprayed in there a little to lube it up, still not sure if it's working properly 'cause I still don't feel the VIAS working.
I'm going to do another test to verify the L-shaped rod is moving properly under no load.
Keep silicone containing products away from the engine intake. It takes very little silicone to render O2 sensors junk. The silicone survives the combustion process and is impinged on the "business end" of the sensor.
Old May 26, 2004 | 05:28 AM
  #51
spirilis's Avatar
Point well taken...
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
