Knocking, banging in front end....
Old May 23, 2004 | 04:04 AM
Proceedbob's Avatar
My 2003 6 speed SE has been making a low frequency knock banging when transiting over rough pavement and it seems to be getting worse, had it on a lift and found nothing amiss. Motor/transmission mount possibly, anyone else experience this?
Old May 23, 2004 | 04:29 AM
DanL's Avatar
Possibly a bad sway bar link. Try twisting them both by hand (temporarily removes the ball joint slop) and see if the noise goes away for a little while.
Old May 23, 2004 | 08:30 AM
6SPD_HLSD's Avatar
Did you have the lower control arm recall done? That might fix the issue.
Old May 23, 2004 | 09:39 AM
Proceedbob's Avatar
I looked around and can't find a service bulletin on this issue for a 2003, could you direct me to it, as my dealer really doesn't keep abreast of such things. Thanks in advance.
Old May 23, 2004 | 11:09 AM
6SPD_HLSD's Avatar
You can check Nissan's webssite but you are right, that recal is for 01-02 Maxes. Did you take out one of the Nissan tecs to hear what the car is doing? They can install chassis ears on the car to listen to what's going on and pinpoint it. You should still be under warranty.
Good luck.
P.S. Does this happen when you are driving in a straight line?
Old May 23, 2004 | 12:46 PM
Proceedbob's Avatar
Good luck.
Yes it does and it is still under warranty, I just didn't want to subject myself to the pain of bringing it in repeatedly until they found it. They do a much better job when I tell them whats wrong.
adamgalazka
Feb 5, 2023 08:24 AM
wyobbagy
Jan 3, 2023 12:03 PM
GregL65
Sep 5, 2015 09:37 PM
jfl330
Sep 4, 2015 01:44 PM
