long term damage due to crank sensor or Ignition coils?
Old May 30, 2004 | 04:44 PM
FusionAcid's Avatar
I think i have two problems....crank sensor failure and ignition coil failure.
Is there any long term damage I can have on my engine if i have been ignoring the problem for few months?
Also, what possibly could go wrong If i do have these 2 issue's with my car?
Old May 30, 2004 | 05:10 PM
Zero Deuce SE's Avatar
How did you determine the failure of the parts you listed? I was under the impression that if your crank sensor goes out your car will stall and not restart.
Old May 30, 2004 | 07:44 PM
ZIPPIN's Avatar
Mauja He Mauja
get it towed to the junk yard..j/k
why do you think the car has the mentioned probs..did you get it diagnosed??
Old May 31, 2004 | 09:57 AM
FusionAcid's Avatar
ok well this is my problem for the past month. I have an SES code P1320. I took it to my mechanic. He said that he is not sure what the problem is but thinks its the crank sensor. I did some research and ask some org members...they said p1320 is ignition coils. My mechanic said he is not sure about that. I have noticed some power loss since the SES came on. My car does hesitate at times. I noticed when you start the engine 1/15 times it doesn't rev up correctly(hesitation). WHO should i trust, mechanic or the P1320 code. I don't wanna get tripple raP3d, my *** can handle only 1 of these fixes. Already spent $200 trying to fix this with replacement of 2 SENSORS and didn't fix the SES light. I don't wanna try replacing parts I don't need to.
by the way my car is:
2000 Maxima GLE , w/ 69k miles
I NEED YOUR EXPERTICE ADVICE PEEPZ!
THANKS
Old May 31, 2004 | 10:36 AM
LiquidhMax's Avatar
that sounds like coils to me. and you got a 2k at that mileage my coils went also (72k) im sure someone here can tell you how to test to see which coil is gone, etc i dont know how personally, they fixed it before i bought the car.
Old May 31, 2004 | 10:49 AM
I'd agree with the coils diagnosis based on other org members problems like yours.
Old Jun 1, 2004 | 11:27 AM
darrelfsu's Avatar
I replaced my coils 10,000 miles ago for the same code and SES light. Maxima has no SES and no stuttering. Go figure.
kjlouis
Nov 24, 2018 06:09 AM
sake1bs
Sep 19, 2015 09:32 PM
iflexsteel
Sep 15, 2015 03:37 AM
maxima297
Aug 3, 2015 12:50 PM
