What can cause very low miles per gallon?
Old Jun 5, 2004 | 11:44 AM
shabzone's Avatar
Hi I have a 2k max and I've noticed that in the past month I'm getting very low mileage per tank. Right now I have a bit less than a quarter of the tank left and I have gone only 164 miles. I don't drive really aggressively and even though its mainly city streets I should get a lot more than that right? What can be causing this problem?
Old Jun 5, 2004 | 12:11 PM
paralyse's Avatar
I Miss My Maxima
O2 sensors, bad gas, dirty air filter, underinflated tires, excessive lead in your right foot, clogged exhaust, fouled spark plugs, etc, etc, etc...
Old Jun 5, 2004 | 12:16 PM
Yaco_Max's Avatar
In another words get your car tunned!!!!!!!!!
Old Jun 5, 2004 | 05:00 PM
00MAXI's Avatar
Throw some BG44k in the tank. That will clean out the injectors. Sounds like you need to do a big tune up. Are you getting any CELs?
Old Jun 5, 2004 | 05:20 PM
BrandonSE's Avatar
I have been trying to dianose that also, i get the EXACT same milage. I have tried fuel injector cleaner, had an oilchange done 1000 miles early and made sure the tire inflation is exact. I have had to replace 1 o2 sensor, and dont know what else. I got a new air filter i guess having 56k miles is a sign to get new spark plugs?... Good luck finding an answer shabzone
Old Jun 6, 2004 | 01:29 AM
CJ7's Avatar
CJ7
Driving style won't equate to 164 miles on 3/4 of a tank. I just filled up my tank today and I fill it up about where your at and I'm at 330 miles. That only get me to about 22-23 miles per gallon and your just over 10MPG. My Jeep gets better mileage then that.
I'd look real hard at you injectors, spark plugs, air filter, and MAF. If I had to guess I'd say injectors.
Old Jun 6, 2004 | 05:27 AM
maniax's Avatar
hahahaz......when i get to where you're at i get about 160miles.......been burning gas like crazy.....i definitely need a tune-up but too lazy and no money. I was thinking of selling the maxima and possibly adding a few grands for the Scion TC. Don't know if that's a smart move. =/
Old Jun 6, 2004 | 09:19 AM
shabzone's Avatar
edit: no check engine lights
BTW my car has just 27k miles on it.. Is it possible for so many things to be messed up already?
Old Jun 6, 2004 | 09:25 AM
NYPD-Arnold's Avatar
Z
If you like driving like a snail, sure. The extra couple of grand you add to the Scion will cancel out if you keep the Maxima, since it'll eventually be used for gas anyways.
Don't get a Scion - they're such terrible cars.
Old Jun 6, 2004 | 10:59 AM
00MAXI's Avatar
27k hmmmm Just change out your air filter and pour some fuel injector cleaner. If that doesn't work take it to the dealer.
Old Jun 6, 2004 | 11:22 AM
R.I.P. Grandma's Avatar
City driving really kills the gas milage.
When i drive in NYC i usually get around 12 to 15mpg. Then i went upstate and found out i was getting around 29 to 32mpg. Considering that you have such low miles on your car i would first check the tire pressure and if thats not the case and you dont have any codes then im not really sure.
Old Jun 6, 2004 | 01:31 PM
maniax's Avatar
same here.....my car only got 28k miles on it......bought it at 22k....havent had a tune up yet.
Old Jun 6, 2004 | 01:52 PM
njmaxseltd's Avatar
The A/C compressor is running all the time if you leave the auto climate control on. Couple that with city driving and your mileage goes down hill fast.
markevans999
Oct 25, 2015 08:27 AM
LtLeary
Sep 14, 2015 12:33 PM
videomano
Sep 8, 2015 03:28 PM
TheMafia
Sep 4, 2015 08:26 AM
crazyespn
Sep 3, 2015 01:30 PM
