ECU reset
Old Jun 9, 2004 | 05:30 PM
Murf300's Avatar
ECU reset
Don't flame me! I have read the FAQs, and it said to disconnect the battery for at least an hour. I thought I remembered reading in the past that did not work, that you had to go through some combination of key turns, and button pushes, etc. Does the battery disconnect really work?
Old Jun 9, 2004 | 05:35 PM
goldmaxNYC's Avatar
on 2000 and 2001 it does not on 02-03.
on 5.5 gen u have to go through that whole procedure
Old Jun 9, 2004 | 06:29 PM
callmezeus's Avatar
Finally an advantage we 5.0 gens have over 5.5 gens.
Old Jun 9, 2004 | 10:10 PM
limsandy's Avatar
Seeing that you have a 2003 Maxima, this is what you'd do:
http://www.technosquareinc.com/350reset.htm
Now, the 350z and the 2002-2003 maxima presumable have the same ECU, so they share the same ECU reset procedure. Enjoy.
Disclaimer: I cannot be held responsible for any damages you do to your car. Hint: Do this while the engine is NOT running.
~limsandy
Old Jun 10, 2004 | 02:17 AM
goldmaxNYC's Avatar
just curiosity before i do the reset also... has anyone done the reset on 02-03? using that http://www.technosquareinc.com/350reset.htm procedure... ?
Old Jun 10, 2004 | 02:46 AM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
i have to disagree with you goldmax...after my ses light(headers) came on i had disconnected my battery for about 4 days...and now my max is running a lot smoother and pulls harder
Old Jun 10, 2004 | 03:34 AM
goldmaxNYC's Avatar
OK. no argument from me. but i dont have 4 days that i can be without my max.. well.. maybe next time i go on a cruise, i'll try it ..
Old Jun 10, 2004 | 04:04 AM
SC02Max's Avatar
Reset Procedure
~limsandy
Curious ..... While looking at the TS website instructions for resetting ECU; do we have to perform the "Accelerator Pedal Release Position Learning", "Throttle Valve Closed Position Learning" and "Idle Air Volume Learning (Throttle Position Learning)" in addition to the ECU reset?? or are those additional procedures for people that have a reprogrammed ECU fro TS??
Thanks for the info.
Old Jun 10, 2004 | 04:16 AM
Rafe's Avatar
You only do this procedure if you have installed a intake of some sort . For some reason after installing the intake our throttle sensor goes haywire. It has happen to me and others on this board. I didn't have time to fiddle with the procedures so i took my Max to Autozone and they hooked up there diagnostic gizmo and reset it for me for free. Got love Autozone!
Old Jun 10, 2004 | 04:28 AM
mdemonte's Avatar
Ecu
I got this info from someone website and I don't recall who.
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON.
A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Old Jun 10, 2004 | 04:42 AM
mdemonte's Avatar
ecu link
Here a link of another procedure
http://maxima.theowensfamily.com/ecu.asp
Old Jun 10, 2004 | 09:36 AM
Rafe's Avatar
Originally Posted by Wolfgraen
So should this only be done for a new intake? I just put on a new exhaust and was wondering whether I should reset the ECU or not.
Only if you take out the cat and you have to custom install your 02 sensor, or you buy a high performance cat.
Old Jun 10, 2004 | 10:08 AM
NewLoveI30's Avatar
I always thought it was a good idea to reset the ECU after any performance mod. Well I guess its a lot easier for my since I only have to disconnect the batt. for a bit.
Old Jun 10, 2004 | 11:31 AM
Wurf's Avatar
That Owens family sight is great! Lots of great pics and info. Nice job whoever the member is that owns it.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
220k+ A32
Sep 22, 2015 03:08 PM
Colossus
Sep 9, 2015 05:46 AM
