Is it worth buying an SAFC even though I'm N/A?
Old Jun 12, 2004 | 05:14 PM
MAXINXS's Avatar
I have been thinking about doing this for a while now. I read through past threads and never got any conclusive responses. I have Hotshot headers, b-pipe, intake, muffler and udp. I know this many mods make the car run lean, and I have always heard that correcting the a/f ratio will provide gains. I read that the optimum a/f ratio is ~14. When I had my car dynoed, I was at 12.5 at 5700 rpm and at 13 most of the run from 4000 rpm on. I know someone has to have tried this by now. Should I get one?
Old Jun 12, 2004 | 05:39 PM
KLOOGY's Avatar
L33t BMW Drivah
It can be of value. Most guys that are modded , and NA can make use of it. Properly tuned it can prevent you from running lean when you have headers etc. That seems to plague most modded Maximas. Just make sure to get it properly dyno tuned......
Old Jun 12, 2004 | 06:11 PM
Triple8Sol's Avatar
I miss the .org!
I think I may have to get either an SAFC or EManage when I do HS headers later this summer. Gotta do some research before I figure out which one though...
So yes, it can be of benefit for NA Powah
Old Jun 12, 2004 | 06:34 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
You're not going to be running lean. If anything, the ECU will have it richer than ever right now. I bet you average A/F ratio is 13:1 as you sit at this very moment...
Old Jun 12, 2004 | 09:45 PM
MAXINXS's Avatar
Yes, that's about right. So, adjusting it to 14 would improve performance right?
Old Jun 12, 2004 | 09:51 PM
KLOOGY's Avatar
L33t BMW Drivah
Im goin by the 3.5's Ive seen dyno with headers......who knows
Old Jun 12, 2004 | 10:09 PM
Dave B's Avatar
Not DAVEB the parts guy
14:1 is good to about 5000rpms or so then you want to start dialing it back a bit to around 13:1-12.5:1. I have the JWT ECU and every dyno I've seen shows the A/F 14:1 across the whole board instead the factory A/F of ~14:1 dialing back to 12:1. 14:1 across the whole band is not ideal nor terribly safe especially when a few of us are pushing 7000rpm rev limiters. I'll probably get a S-AFC to richen up the mixture a bit.
Dave
Old Jun 13, 2004 | 09:29 AM
MAXINXS's Avatar
Dave
So what exactly will I gain or lose from dialing back the a/f at ~5000 like you are talking about? Is it just easier on the engine?
Old Jun 13, 2004 | 11:22 AM
Larrio's Avatar
The Definitive AE Master
its not safe running a lean condition at higher rpms, so therefore most of the time the mixture is increased to a richer A/F after 5k rpms
my ecu is a consistent 12.4-12.8 across the whole band
Old Jun 13, 2004 | 01:13 PM
MAXINXS's Avatar
Found a great articel that pretty much explains everything: http://www.nissanperformancemag.com/...roject_qg18de/
jmlee44
Oct 2, 2022 02:13 PM
Forge277
Jun 13, 2016 09:26 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
