Magnaflow Muffler... Interior sounds are annoying.. Need Suggestions...
Old Mar 29, 2001 | 05:02 PM
tomI30's Avatar
I just installed the Magnaflow muffler and the outside sounds like a low bass sound. The inside while traveling on the freeway at 70mph at 2500rpms is very annoying and has a constant bass sound. Should I do a dynomat installation? Do I need to change out the resignator (Spelling)? I don't mind a mean car sound like Y2KevSE's, but mines a low bass sound that doesn't sound mean at all, just annoying. Oh yeah, will a Y-pipe change the sound as well as the resignator? Thanks for the help.
Tom 2kGXE
Old Mar 29, 2001 | 05:14 PM
y2kse's Avatar
Tom 2kGXE
70 mph at 2500 rpm . . . must be nice. You OBVIOUSLY have an automatic.
All Magnaflow mufflers tend to drone at around 2500 rpm. Mine does as well. But I have a manual transmission and at 70 mph, my engine rotates at 3,000 rpm. That's well past the drone range. And if you still have your stock resonator in place, replacing it with another will probably do you no good.
One thing you could do is turn off your overdrive. That would bring up your rpm and reduce the drone. But it will play hell with your gas mileage.
Old Mar 29, 2001 | 05:30 PM
tomI30's Avatar
Thanks for the advice, I'll try turning the overdive off while driving home. I'll touch base with the results when I get home.
Old Mar 29, 2001 | 08:57 PM
PKO's Avatar
PKO
Hey y2kse
I did a search on the Dynomax Turbo muffler and found you had an exhaust setup I was thinking of doing. You seemed to be happy with the Dynomax. Why the change to the Magnaflow?
Old Mar 29, 2001 | 10:38 PM
tomI30's Avatar
I turned the OD off during my drive home and the RPM's were too high 4000rpms. Oh well, looks like I'm getting some sound detening material soon. Thanks for the advice though.
Tom 2kGXE
Old Mar 29, 2001 | 10:54 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hmmmm... putting a larger resonator on the b pipe will definitely help.
A y pipe will DEFINITELY increase the noise. VVVVRRRROOOOOOOOOMMMMMM!!!!!!
Old Mar 30, 2001 | 05:06 AM
DNA21's Avatar
The y-pipe will definitely increase the exhaust noise (especially if you have remove the resonator and added an aftermarket muffler). However, you should be able counteract this by getting an aftermarket resonator and replacing the stock unit. Just get a high quality unit free flowing unit.
Old Mar 30, 2001 | 05:57 AM
OzziSVT
Dynomax Bullet 2.5" $35. That will kill a lot of the drone. Stay away from Cherry Bombs, Thrush and Turbo Mufflers. They are all restrictive, especially the Turbo mufflers. Dynomax's Ultraflow mufflers are awesome. You could always buy a round shell Ultraflow (17230 - $70) instead of a Bullet to use in the stock resonator position, instead of a Bullet, if it fits (they are 6" in diameter). This will quieten it down a lot and make it more bassy. Check out Dynomax's website (www.dynomax.com)and find a part number, then just order the Ultraflow through Summit racing (www.summitracing.com).
Old Mar 30, 2001 | 09:03 AM
tomI30's Avatar
How does your bullet 2.5" Dynomax sound? It's the low bass sound that kills me....
Tom 2kGXE
Old Mar 30, 2001 | 09:41 AM
OzziSVT
Tom 2kGXE
Tom,
actually it is the pipe under your cabin resonating that is killing you. The Bullet attenuates the frquencies that are responsible for resonance, so it will sound deep, but not boomy.
Old Mar 30, 2001 | 10:17 AM
tomI30's Avatar
Tom,
Wouldn't deep make it sound even louder?
Tom 2kGXE
Mahmuth
Aug 16, 2024 08:23 PM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
Justin Kroll
Oct 1, 2015 07:03 PM
