Homelink...tell me more
well merry x-mas
http://www.nissan-techinfo.com/nissa...p?dept%5Fid=37
Still Here... IM me for more..
Originally Posted by Shift_VQ
How do you program it/cancel it etc? I bought my car used and I dont have a manual.
2. Hold the end of the hand-held transmitter (the garage remote) approx 2-5 inches from the surface of the Homelink, keeping the indicator light in view.
3. Using both hands, simultaneously push the hand-held transmitter button and the desired HomeLink button. Do not release the buttons until step 4 has been completed.
4. The HomeLink indicator light will flash, first slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. The rapid flashing light indicates the integrated HomeLink Universal Transceiver has been successfully programmed.
PROGRAMMING HomeLink
1. With the ignition key in the OFF position,
press and hold the two outside buttons, and
release when the indicator light begins to
flash (approximately 20 seconds). This procedure
erases the factory set default codes
and does not have to be followed when
programming additional hand-held transmitters.
(from the device you wish to train) approximately
2 to 5 inches (50 to 127 mm) away
from the surface of HomeLink keeping the
NOTE:
Some garage door openers may require
the procedures noted under “Canadian
Programming”.
indicates the Integrated HomeLink Universal
To program the remaining two buttons, follow
steps 2 through 4.
If, after repeated attempts, you do not successfully
program the Integrated HomeLink
Universal Transceiver to learn the signal of the
hand-held transmitter, refer to “Rolling Code
Programming” later in this section.
NOTE:
Programming”.
steps 2 through 4.
Originally Posted by Ammi
I couldn't get mine to work after number of tries.
Originally Posted by kcowden
What do you do when you have two garage doors? I programed my door and now when I push the button BOTH doors open, so mine is useless now any help would be appreciated.
Originally Posted by schernov
You have to set them to use different channels. there should be several little switches in the unit that you can flip to change the setting.
I'm assuming your talking about the remote that came with the opener.... I'll try that and thanks!
