Passenger Front Window Screeching
Old Jun 20, 2004 | 08:20 PM
ArMiXiA's Avatar
Hey guys, when I open or close the passenger front window it screeches as if there was no oil in the power thingy (?) Was wondering if anyone knew how to fix this problem?
Old Jun 20, 2004 | 11:13 PM
MIXXMAX's Avatar
Try spraying some silicone spray along the track where the window rides along the rubber strip. This usually works.
Old Jun 21, 2004 | 03:56 AM
Y2K1JKSE's Avatar
yup that should just about do it...i have the same exact problem and yet i've been too lazy to do it haha
Old Jun 21, 2004 | 06:46 AM
Skizza20's Avatar
YES! I have the same problem on my Max but I kept forgetting to post about it. I'll grab some spray ASAP and see if it helps. Good looking out
Old Jun 21, 2004 | 06:49 AM
2k3TitaniumSe's Avatar
Try some WD40.
Old Jun 21, 2004 | 04:52 PM
Max2000SE's Avatar
Wd-40 works but it only worked for me for about a week. I just did it again on saturday and also used some stuff from pep-boys called "GOld Magic" (or something around that name) its basically just a grease and has worked well up to this point, but for sure its that rubber seal along thr inside door.
Old Jun 22, 2004 | 05:04 AM
silversurfersg's Avatar
dont use liquid
Old Jun 22, 2004 | 07:53 AM
Skizza20's Avatar
Originally Posted by silversurfersg
dont use liquid
What will work better?
Old Jun 22, 2004 | 08:45 AM
schmatt's Avatar
Nissan sells a silcone spray for about $5. Go get that at your local dealership. I did about a couple of months ago and have yet to have any more screeching sounds. Not only that, but it will work great for just about anything else that needs lubrication on your car or around the house.
Old Jun 22, 2004 | 01:16 PM
SoonerFan's Avatar
Cletus
How to fix problem of windows rolling up slow and squeaking.
RED - Run a wet rag in the window track then spray whole thing with silicon spray.
BLUE - Wipe inside both rubber pieces with wet rag.
Old Jun 22, 2004 | 08:12 PM
maxima0002's Avatar
Will White lithium Grease do the trick?
Old Jun 22, 2004 | 08:20 PM
SoonerFan's Avatar
Cletus
you want silicon because it is water based (or KY i guess). anything potroleum based will be bad for the rubber and streak the window.
Old Jun 22, 2004 | 11:03 PM
panda_1's Avatar
so basically use KY Jelly.
Old Jun 23, 2004 | 04:48 AM
ZIPPIN's Avatar
Mauja He Mauja
naughty boy , we are talking about windows. not your $ex life
Old Jun 23, 2004 | 04:49 AM
ZIPPIN's Avatar
Mauja He Mauja
i think wd-40 will attract dust etc. do what soonerfan posted
Old Jun 23, 2004 | 02:43 PM
MIXXMAX's Avatar
No, don't use lithium grease. It will only make matters worse. It will smear the h*** out of your window. Just go to your local auto parts store and pick up a can of silcone spray. This works wonders! And it only costs a couple of dollars, maybe $2-$3 at the most.
Old Jun 23, 2004 | 02:45 PM
FusionAcid's Avatar
i have the same problem. Will this mess up my tints if i do that spray?
Old Jun 23, 2004 | 08:34 PM
panda_1's Avatar
NAHH MANG DONT USE THAT STUFF I USE VASELINE!!! CUZ YOU KNOW I PREFER THE STICKINESS AND THE HEAT IT CAUSES.
BUT, SERIOUSLY dont USE WD-40 BESIDES THE FACT THAT YOU WOULD HAVE TO REAPPLY IT EVERYTIME AFTER IT RAINS, OR YOU WASH YOUR CAR. IT RUNS THE ENTIRE WAY THROUGH THE INSIDE OF YOUR DOOR AND IT MARKS ON YOUR PAINT AFTER IT COMES OUT ON THE UNDERSIDE OF THE CAR.
Old Jun 23, 2004 | 08:38 PM
alicious's Avatar
the org...not what it was
We discussed this a while back, go here http://forums.maxima.org/showthread.php?t=312215
and no, it wont mess up the tint at all.
Old Jun 27, 2004 | 05:37 PM
maxima0002's Avatar
Hey guys.. what about this Silicon spray that has petroleum distillate in it, but the label says for "rubber". Should I use it? I know anything petroleum is no good, but it says for metal, rubber..
it's generic stuff in a spray bottle from Canadian Tire ..
maximusrising
Sep 2, 2015 09:55 AM
max1029
Aug 26, 2015 09:51 AM
doctorpullit
Aug 20, 2015 05:15 PM
KGMtech
Aug 18, 2015 09:21 AM
kjm900r
Aug 5, 2015 07:14 AM
