Programing a Transponder Key 2K Max?
Old Jun 22, 2004 | 05:20 PM
BLCKMAX's Avatar
I ordered one of these keys off ebay. I guess they are for the 2000-2001 Maxima. Was about $24 with shipping. I know there is a chip on the key, I also know that going to the dealer will be a fortune. Does anyone know approx. the price at the stealership? or anyother place where I can get it done, and how much.
Old Jun 22, 2004 | 06:00 PM
Ben's Avatar
Ben
I payed $45 at a local dealership to cut and program 2 keys.
They insisted they would not work. Said something special about the 2000. I pushed and they agreed to try it but that they would charge me either way. Tech was a real jerk about it. Anyway, they worked fine and the tech hid his face and wouldn't talk to me afterwards.
Another stealership quoated me $80.
I also found 2 locksmiths who said they could do it, but they wanted $40/key.
Moral? Shop around.
Old Jun 22, 2004 | 10:36 PM
xTeCaOx's Avatar
Moral? Shop around.
whoa i had a key cut and programmed over here at a local $tealer and that cost me about $100, about $45 to cut and $50 to program......
Old Jun 22, 2004 | 10:41 PM
ChromeSE5's Avatar
depending on where you go, its gonna be around $50 for programming. The price you paid for the key is also really good. The average price dealerships and locksmiths charge range from $45 to $80.
Old Jun 23, 2004 | 05:33 AM
desperado_45's Avatar
Two keys cut and programed same day $45.00 and they were NVO keys.
Old Jun 26, 2004 | 01:59 PM
BLCKMAX's Avatar
hrm. thanks for all the responses. Anyone from NY has any good dealerships?
Old Jun 26, 2004 | 03:42 PM
BLCKMAX's Avatar
cough cough I meant STEALERSHIPS
Old Jun 26, 2004 | 07:13 PM
SKYRockerr's Avatar
how do they program, i wana buy those transponder keys and have them programmed .. im looking to buy off ebay, i gotta 02.. , i bought a remote it works fine and i programed it.
Old Jun 26, 2004 | 07:18 PM
SKYRockerr's Avatar
i only have one key for my car .. i was thinking instead of paying **** load of $ to stealer****s .. buy a remote starter
Old Jun 26, 2004 | 08:12 PM
Ben's Avatar
Ben
Remotes can be programmed by anyone. Keys have to be programmed with consultII or similar. Dealer and a few locksmiths are the only ones who can do it.
Also, if you get a remote start, your ONLY key would be installed in the car so the remote start could operate. This seems like a bad idea. Don't most remote starts still require that you put the key in to actually drive the car?
Old Jun 27, 2004 | 10:04 AM
BLCKMAX's Avatar
Yes you are right, you still need a key, and yes that would be a bad idea
Old Jun 27, 2004 | 04:12 PM
SKYRockerr's Avatar
Instead of a dealer key, all you need is a key that goes in accesseri right? right? well i went ahead just as a experiment and got a key done at homedepot, it works fine on doors and trunk and cr goes in accessory but it wont start... with remote starter and home depot accessory key, it should work right right.. i maybe wrong, thats why i come to you people
Old Jun 29, 2004 | 03:14 PM
Thaniel's Avatar
The ECU stores the code of the transponder that is burried in the key. The code is put in the ECU when the ECU is programmed with the consultII and the key. If you try and start the car without sending the code to the ECU (no transponder key) the car will not start (security LED will stay lit when key is turned to on). Try to start the car too many times with a non programed key and the ECU will go to lock mode, meaning you will have to do some on off sequence even when you do get the programmed key to get it to start. It is a pretty secure system. Most remote starters I have looked at don't bypass the system they just put a key somewhere in the system to transmit the code when trying to start. One unit I saw didn't have a key in it but it had to be programmed into the ECU just like a key (trip to a dealer and $).
Old Jun 30, 2004 | 04:27 AM
SKYRockerr's Avatar
Thank you, that clears up alot of missunderstanding i had. so in simple english i am going to have to spend $90.00
Old Jun 30, 2004 | 07:09 AM
john5820's Avatar
How come my .98 cent key from walmart worked on my 2000 maxima?
Old Jun 30, 2004 | 08:13 AM
Thaniel's Avatar
Try it again but make sure the original transponder key is no where near the car.
Also be sure that no one installed an aftermarket remote starter with a tranponder key embeded in it.
Old Jun 30, 2004 | 09:51 AM
john5820's Avatar
oh, your right, I never fully started my car with that key. sorry
Old Jun 30, 2004 | 11:31 AM
SKYRockerr's Avatar
There ya go, we need a cheap solution to these transponder key programing.
litch
123
Jan 4, 2024 07:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
Marc2theMax
Sep 28, 2015 08:13 AM
