How To For GAB?
Old Jun 23, 2004 | 04:33 AM
96max5sp's Avatar
How To For GAB?
Hi, is there anyplace I can find a write to do the GAB mod? I would like to do this since there have been god reviews about this "mod". If not can someone make a write and put it in one of the stickies up top like the how to section?
Old Jun 23, 2004 | 06:09 AM
2k3TitaniumSe's Avatar
PM Soonerfan.
Old Jun 23, 2004 | 07:17 AM
96max5sp's Avatar
Originally Posted by 2k3TitaniumSe
PM Soonerfan.
K, i just PMed him, Thanks
Old Jun 23, 2004 | 09:15 AM
Fezzik's Avatar
http://home.insightbb.com/~dwh/GAB.htm
This is my write-up on it. This will keep you from destroying the filter holder
Old Jun 23, 2004 | 10:14 AM
96max5sp's Avatar
Wow, nice detailed write up, thanks!
Old Jun 23, 2004 | 12:15 PM
SoonerFan's Avatar
Cletus
96max5sp,
just PMed you back. you can also use Fezzik's method. my mentality is that even with a piece cut out of mine, it looks stock to most people. so if i sell it, they wont know the diffirence.
Old Jun 24, 2004 | 07:30 PM
ABS's Avatar
ABS
Check my home page for another option.
Old Jun 25, 2004 | 04:58 AM
96max5sp's Avatar
Thanks guys for all your ideas, i am going to experiment with them hopefully this weekend and see which works best
Old Jun 25, 2004 | 01:53 PM
BP's Avatar
BP
i've been running this setup for about 2 months and have been very pleased. as long as you use the thick gauge wire you can shape the wire well enough that it will securely hold the filter in place. i've tugged on mine and doesn't budge. one of the best things is when i took the car in for the 30k service i just put the stock filter holder right back in just to avoid any questions and warranty threats.
low end torque is slightly off and this setup is definitely not for show, but the convenience and overall improvement in performace makes this mod well worth the cost.
Old Jun 25, 2004 | 09:33 PM
Fezzik's Avatar
Hey BP_3.5. Glad you like it. That's the whole reason I did that. I sat there and thought. How can i do this and be able to put it back to stock when needed.
Name brand intake... ~300 dollars
GAB... ~ 5 cents...
Old Jun 26, 2004 | 06:43 AM
fishhouse's Avatar
GAB... ~ 5 cents...
or, Injen knock-off from ebay... ~$45.
i tried several variations of the GAB as well as the OSCAI and ran with them many times. personally, i think the extra $44.95 for the generic Injen (based on your .05 cost of the GAB) is well worth the money.
also, if you do the GAB or OSCAI you should for sure consider investing in a K&N or similar filter - which jacks your .05 cost up anohter $45. that essentially makes the knock-off Injen intake a better buy! not to mention it looks better and isn't ghetto.
just my .02!
Old Jun 26, 2004 | 07:02 AM
ABS's Avatar
ABS
I wouldn't recommend using anything other than an OEM style paper filter. Oiled cotton and foam filters both let in a LOT more dirt than the paper filter. Just something to consider. The mod I did resulted in only a very slight drop in low end torque, barely noticable, kept the engine quiet and added quite a bit up top. I still use an OEM paper filter which was a priority for me. Good luck whatever you choose to do.
Old Apr 16, 2008 | 01:16 PM
MaxinO2's Avatar
I was wondering is anyone could help me out with a writeup on GAB for my 02' Max... I could not find any writeups or valid links on how to. Thanks
Old Apr 16, 2008 | 02:20 PM
Deckdout2's Avatar
Play with my balls
Holy bump thread day batman......
Just hack the top dude, and take 2" hole saws and drill a couple holes in the face of the box.
Now go outside, and look at your box. Then look at this picture and make it look the same.
No more GAB thread bumps from you today.
Old Apr 16, 2008 | 02:46 PM
hotstartup's Avatar
that looks pretty crappy. id just drill holed at the top end, and gut the resonator.
Old Apr 16, 2008 | 03:22 PM
Deckdout2's Avatar
Play with my balls
You're absolutely right. It does look like s'hit. That was to give him an idea. That was also about 3 years ago. It's since been cleaned up (top and holes) since.
Old Apr 16, 2008 | 03:25 PM
Deckdout2's Avatar
Play with my balls
More recent.......
No more-a look-a like-a s'hit-a
Old Apr 16, 2008 | 05:48 PM
Squirrel82's Avatar
What part is the resonator?
Old Apr 16, 2008 | 06:16 PM
NmexMAX's Avatar
dot dot dot ...
Does it matter?
It’s the big black plastic box in between the TB (Throttle Body) & MAF (Mass Air Flow sensor). It is connected to the TB by an accordion-like 'tube'. It has a PCV line (rubber) running from it (resonator box) to the front VC (valve cover).
It's uses Helmholtz type of resonation physics, and provides the best, most linear power curve.
Old Apr 16, 2008 | 06:27 PM
MaxinO2's Avatar
So basically im hacking at the top part of the airbox and drilling two holes in the front for more airflow? Is there anything else I should know? Sorry guys im a noobie to this.
Old Apr 16, 2008 | 06:34 PM
NmexMAX's Avatar
dot dot dot ...
The GAB mod does not require to cut anything alctually.
Old Apr 16, 2008 | 06:36 PM
SoonerFan's Avatar
Cletus
dear god people....one of the oldest mods on here...and people have no clue how to do it
Old Apr 16, 2008 | 06:41 PM
NmexMAX's Avatar
dot dot dot ...
You seem surprised?
Old Apr 16, 2008 | 06:43 PM
SoonerFan's Avatar
Cletus
i thought the "resonator" was the clear plastic part that connects the the bottom of the stock airbox (my 00 GLE had one but my 02 SE doesnt...so it is a 00-01 thing? or a GLE thing?)
Old Apr 17, 2008 | 06:16 AM
Deckdout2's Avatar
Play with my balls
If you use the coat hanger method than you're right.
Old Apr 17, 2008 | 07:13 AM
Tee00Max's Avatar
DeckDout does thats do a lil better to you when you took all that black plastic that was connected off????
Old Apr 17, 2008 | 07:27 AM
Deckdout2's Avatar
Play with my balls
I couldn't say if it's better or not, but the idea is to open up the box more to make it as less restrictive as possible. With the snorkel off it's definately less restrictive so in a way you can say it's better.
Old Apr 17, 2008 | 07:30 AM
NmexMAX's Avatar
dot dot dot ...
The Helmholtz resonator is what is what I was referring to. I am using an 01 box in my 03 right now. I did not receive the ducting, only the box, so, technically, the airbox is the same (01 & 03).
Old Apr 17, 2008 | 07:43 AM
Tee00Max's Avatar
i was thinkin bout puttin a cone filter on mine but does autozone or somewhere have the adapter for it for the MAF???
Old Apr 17, 2008 | 12:20 PM
NmexMAX's Avatar
dot dot dot ...
Somewhere probably does, but not AutoZone.
Sep 27, 2015 08:37 AM
NmexMAX
Dyno Discussion and Slips
37
May 9, 2006 06:21 PM
wade2ksleeper
Jul 7, 2004 10:42 AM
MaxMafia
21
Dec 2, 2003 04:35 PM
Ryanb126
Nov 30, 2003 02:30 AM
