Stops pulling around 3400 RPM?
Old Jun 23, 2004 | 10:04 AM
dvanorder's Avatar
Hi everyone,
My 5 spd seems to run fine, I have a bone stock 2000 GXE with a drop in K&N air filter only. I am the second owner, it has 65K. The car pulls like crazy up to around 3400 RPM, then you can feel a change, almost as if the cam profile changed to something less aggressive, and the car stops pulling, changing to a smoother/slower acceleration. There's no bucking, just a slight SOTP change. Does this in all gears. I can't imagine valve float or anything like that at such a low RPM. Maybe coil pack(s) that are going south, but not enough to throw a code?
Thanks!
Old Jun 23, 2004 | 10:14 AM
Kiosk's Avatar
Originally Posted by dvanorder
Hi everyone,
Thanks!
I had the same problem as you described on mine w/o any codes, after doing all kinds stuff the problem was solved by cleaning my air flow meter (MAF)....
Old Jun 23, 2004 | 10:48 AM
maseo77's Avatar
BUY a new MAF trust me cleaning the old may help but it still needs to be replaced to the newer style nissan has put out.
Old Jun 23, 2004 | 11:02 AM
dvanorder's Avatar
Great, sounds like a plan, and thanks. I cleaned that sucker a year ago, but it may be ready for another one. If it works, I may buy a new one, but I've still got 35K left on the warranty, and suspect MAF's for this are at least $100.
JoshG
51
Sep 21, 2015 10:41 PM
Maxxx10
Sep 13, 2015 03:16 PM
crazyespn
Sep 3, 2015 01:30 PM
